1965 Chevrolet C10 SWB Fleetside Bed, 2005 5.3/4l60 Combo, Disc Brakes, Dakota Dash
Year: 1965
Make: Chevrolet
Model: C/K 10
Price: $9999
Mileage: 268
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Turquoise
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Hard to believe you are actually driving a 1965 truck as it feels like a new chevy truck. Very Very Smooth! We removed the power train from a running and driving 2005 Yukon with 71k Miles. Throttle is electronic and very responsive. This truck has a great patina and a very solid truck with only cosmetic surface rust. I have averaged 22-24mpg, can easily cruise 70-80mph with the 4l60 and 3.08 rear gear. Dakota Digital dash is awesome as it can even record 0-60 time, top speed, quarter mile time along with giving all your vitals gauge signals. I have put right around 300 miles on this cool truck since we completed the build with absolutely zero problems. Can drive this truck right now anytime and anywhere. This truck was professional built by me and my team here at LSx Unlimited. Clean Texas Title in Hand.
Here is all the details on the truck. I am sure there is a few items we installed that are not listed but this is the majority.
1965 Chevrolet C10 Custom Cab, Short Wheel Base, Fleetside Bed
Gen 4 2005 Iron Block 5.3 with 71k Miles
2005 4l60e Transmission from the same vehicle
2005 PCM Tuned by LSx Unlimited
Mobil 1 Full Synthetic Engine Oil
Wix Engine Oil Filter
Hayden Large Capacity Trans Cooler
Custom Driveshaft
2011 Air Intake System with K&N Flter
2011 Chevrolet Camaro 6.2 Exhaust Manifolds
2.5” Dual Exhaust
Flexalite 16” Electric Fan (PCM Controlled)
Custom Built Aluminum Radiator
Custom Radiator Hoses
Jose Quervo Overflow Tank
Custom Built Motor Mounts
Custom Built Trans Crossmember
Late Model Front Power Disc Brake Conversion
1984 Model Steering Gear
1984 Sway Bar with Poly Bushings
Late Model Rear Differential with a Limited Slip 3.08
15” Chrome Steelies all around
Bosch Electronic Fuel Pump
C5 Corvette Fuel Filter Regulator Combo
New Fuel Sending unit with Return Plumbed in (Stock Gas Tank Location)
Dakota Digital Instrumentation with Teal Lens Installed
Late Model Tilt Steering Column
Late Model Steering Wheel
B&M 4L60e Truck Shifter
Alpine Stereo System (Sounds amazing)
All glass is perfect with no cracks or chips. Both Window roll up and down with ease. Weather-stripping is all in great condition with no water leaks. Body is very solid with very little surface rust. Only damage on the body is the right front of the hood (gives it a little character). Truck was restored appox in the early 90’s which there is some body filler on the pass side door and bed (once again looks great with the patina). Bed cross rails and mounting points are all in perfect condition ready for your choice of bed options. Wiper work great and still has the factory heater.
**NEW PRICE, $9999 FIRM!
