Built 1999 Trans Am
Built 1999 Trans Am
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $10000
Mileage: 130000
Private or Dealer Listing: Private Listing
Location (State): OK
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine
*stock LS1 crank polished & rebalanced good 1000+ hp
*Diamond flat top pistons 3.905" BORE / 3.622" Stroke
*Diamond Pro-Select Piston Rings, 3.905 Bore
*EAGLE 6.125" H beam rods
*Custom grind cam By Futral motorsports239 - 251 + 4 / 610 intake & 630 exhaust @ 114
*PRC Stage 2.5 5.3L CNC Ported Heads (milled for 11.5:1 compression)
*Cometic Head Gasket 3.910
*2.02"/1.575" Stainless Steel Valves
*PRC .650" Lift Dual valve Springs, Titanium Retainers, Seats, & Sealsdum
*Comp Cams rods
*GM Racing lifters
*SLP Underdrive Pulley
*SLP Double Roller Timing chaindum
*GM LS6 Oil Pumpdum
*42 # Injectorsdum
*Meziere electric water pump
*Billet Valve cover Breathers
*NGK TR55 plugs
*Taylor LS1 Tundervolts Wiresdum
*LS6 intake, stock throttle body, Maf sensor, SLP lid.
*Stock vavle covers
*Stock oil pan
*Stock coil packs
*Spohn solid motor mounts
Exhaust
*Pacesetter 1 3/4 long tube headers
*off road Y pipe
*Borla Catback exhaust (with electric cutout)
Drivetrain
*RPM level 5 transmission (less than 500 miles)
*micro polished
*tick mastercylinder
*Monster level 3 clutch
*aftermarket chromemoly driveshaft (good for 800hp)
*Dana 60, 35 spline axles, 4.10 Gear, detroit locker, and aluminium cover
Suspension
*umi strut tower brace
*umi tourque arm
*umi driveshaft safety loop
*umi subrfame connectors
*umi panhard bar
*umi lower control arms
The car needs body work to finish it. The car will come with both front fenders, and a rear quarter panel. Car does have a clean title. I'm looking to get $10,000 for the car but i am open to trades as well (bikes, other cars, 4x4s) let me know what you have.
