97 ws6 a4
97 ws6 a4
Year: 1997
Make: Pontiac
Model: Trans Am
Price: $4000
Mileage: 185000
Private or Dealer Listing: Private Listing
Location (State): TN
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
97 WS6. 185,xxx on the body, roughly 5k on new engine. Automatic transmission with roughly 30,000 miles. Still have all paperwork on both. The interior dose show its age and the body dose have a couple small imperfections but nothing bad by any means (I.E. the normal door ding on the rear quarters, and a couple paint imperfections.) Dash pad is NOT busted surprisingly. Only issue is it will need a new optispark at some point. Original was replaced with a cheap one (due to funds), but its not good enough. The car still runs good, rpms just flutter from time to time like its not getting enough spark. Will also need new tires eventually. Can replace both of these issues but price will reflect.
It's pretty much all stock minus.
Drilled and slotted front rotors
K&N panel filter
Descreened MAF
Remote Start
NEW PARTS (all installed within the last 10-15k tops probably much less than that but to be safe well call it that)
New crate LT1 from ATK Engines, roughly 5k on it (all paper work and still under warranty)
Battery
Alternator
Starter
Radiator
Water Pump
Oil Pump (pickup is tac welded on)
Knock Sensor
Oil Pressure Sensor
TPS
Coolant Level Sensor
Thermostat
Upper and Lower Radiator Hoses
Various new hoses throughout
Serpentine Belt and tensioner pulley
Power Steering Pump
Plugs and Wires
Rebuilt 4L60E, roughly 30,000 on it
Will do CETA mod if desired.
Price is pretty firm. Not really looking for trades but may consider a 16-18ish foot bass boat plus cash on your end.
Also have the original long block LT1 that seized that I will sell for additional price.
The engine will come with another new
T-stat
Oil Pan Gasket
Valve Cover Gaskets
