Jeep wrangler rockcrawler fs ft
Year: 2000
Make: Jeep
Model: TJ
Price: $10000
Mileage: 96000
Private or Dealer Listing: Private Listing
Location (State): MD
Color: Green
Transmission: Manual
Drivetrain: 4WD & AWD
On to the Jeep, it's a 2000 TJ with factory 2.5l motor. The transmission is the stock ax5, after the trans is the dnd doubler. The doubler contains a 231 front half with a teralow 4to1 and is then connected to a flipped Dana 300 with a&a 32 spline rear output. Low range gear choices are 4.1 in the doubler 2.62 in the Dana 300. I typically leave the Dana 300 in low and switch the doubler on when I get to an obstacle. When in double low range the craw ratio is around 195 which is slow enough to crawl up anything.
Suspension - front is spring over axle with stock lift yj springs and poly performance BBC shocks.
Rear is a 4 linked with antirock and with poly performance BBC shocks that are notched in to the frame.
The wheel base is stretched to 102".
All hemi joints are ruff stuff cryo treated and are tight.
All links are made with 1/4" wall Dom tubing
With the leafs up front and the links on the back the truck flexs really well but is very stable and predictable.
Axles
Front is a tj rubicon 44 with rcvs and 4.56 gears. The locker is a rear rubicon diff so it's a limited slip when UN locked and at the push of a button is fully locked. The passenger side knuckle is a teraflex high steer knuckle.
Rear axle is a tj 44 with Detroit locker and 4.56 gears.
Crane diff covers on both axles
Steering
ARG steering box with inline cooler
All heim joints with 5/8" bolts for a very strong setup
High steer setup with teraflex high steer knuckle
Interior
Corbua front seats and 4pt harnesses.
Quick disconnect steering wheel
Body
Poison spider fenders and stinger
Warn 8000xi winch
Rci 15 gallon fuel cell using stock sender and pump. Fuel cell is recessed in to the floor behind the rear seat and is cover with a fire wall.
Full doors and soft top Windows
Functioning snorkel system
All stock gauges work
Has ac but system probably needs a recharge
Tires and wheels
Wheels are 15"x8" allied rockathon beadlocks
Tires 37"x13.50" bias ply pitbull rockers
From the bottom of the rockers to the ground is 25-1/2"
Bottom of diff to ground is 10-1/4"
