1991 RX-7 LS Swap Ready
Year: 1991
Make: Mazda
Model: RX-7
Price: $4000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
LS Engine?: Car has LS engine
If interested you are welcome to message me with any questions. Please, only serious buyers need to comment/message. Much of the interior is still out of the car but I can install it all if someone is truly interested in purchasing the car. Keep in mind that the car is still a 91 so it is not perfect but it is in good condition for it's age.
Price: $4,000 and pretty firm at this right now. There is a lot of time/parts put into the car.
Parts List:
New Axle Nuts
New Brake Pads
New Russell Rear Stainless Brake Lines
New Russell Front Stainless Brake Lines
New Lateral Link Grease & Rubber Boots
New Racing Beat Rear Toe Eliminators
New MMR Delrin Diff Bushings
New Front Diff Mazda Comp Mount
New Lower Spherical Bearing Seals
New Pinion Snubber
New Energy Suspension Control Arm Bushings
New Grannys Sway Bar Spacer Kit
New Racing Beat Front Sway Bar w/ Urethane Bushings
New Mazdatrix Front End Links
New Timken Front Hub Races
New Timken Inner Wheel Bearings
New Timken Outer Wheel Bearings
New Inner Seals
New Moog Front Outer Tie Rod Ends w/ Service Port
New Moog Front Inner Tie Rods
New Moog Front Rack and Pinion Bellows
New Moog Front Ball Joints
New Front Brembo Brake Rotors
New Paint in Engine Bay - Color matched to Factory Color
New Foam in all of the HVAC boxes behind the dash. Boxes were disassembled, old foam removed & new foam applied.
New Heater Core
S4 T2 Diff / Axles
S4 Front Lower Controls Arms w/ Replacable Ball Joints
Clearanced Firewall for Longtubes
Clearanced Trans Tunnel for T56 sensors
Applied Undercoat to Wheel Wells & Trans Tunnel
Heater lines relocated with New heater hose and Gates Hose Clamps
Brake Calipers were cleaned & Painted Red with Duplicolor Caliper Paint
Gas Tank was pulled out and cleaned up
I do have some of the swap parts available at an extra cost for anyone who may be interested. This car is not able to have a rotary put back into it without a lot of work and welding the transmission mounts back onto the car.
Thanks for looking.
