FS: 1995 Mitsubishi Eclipse GSX Built engine/trans, 500 AWHP
Means of Contact: PM or email at XxGSXRATEDxX@gmail.com
Description:Built 1995 GSX
Miles:4k on engine/trans
Price:14000, OBO
Additional Information:
After much deliberation, and the decision to invest more money into my LS1 RX7 project, I have decided to sell my beloved DSM. The car is tuned to 502 AWHP on 27psi and 93/110 octane and should do over 550 AWHP on race gas and 30+ psi. The engine has only 4k miles on it and is really just broken in with perfect compression across the board.
This car has brand new 1999 front and rear bumpers that were professionally painted 6 months ago, as well as 1999 OEM black housing headlights, Sylvania Silverstar headlights, 1999 reverse lights, and clear corner bumper lights. I also have a 1999 turbo wing I will throw in if anyone buys the car. It's lowered with H&R springs on tokico illumina 5-way adjustable shocks. The oem swirlies and tires have maybe 3k miles on them also, and have lots of tread. The rims have no curb rash also. I also have a set of 98 gst silver 5-spokes available for sale if someone wants those. The car also has power windows, locks, and remote entry. The car also has the limited slip rear differential that was an option.
Now for the real mods everyone is interested in:
1g built block which includes:
JE forged pistons
Scat forged rods (700+ hp capable)
Fully balanced and blueprinted bottom end
Removed oil squirters
All ARP mains, rod bolts, head studs, flywheel bolts
Ported high volume oil pump
Balance shafts eliminated
Cometic HP headgasket
Race ported/polished 2g head with:
Stainless industries nitrile coated stainless valves
Crower valvesprings/titanium retainers
Comp 101200 cams (think HKS 272's)
Revised 3g lifters
Bronze valve guides
5-angle race valve job
Deburred oil galleys
New oem water pump
New oem timing belt
Optima Red Top battery
Turbo parts:
PTE SCM 6067 Ball Bearing turbo
Polished T04S 4" compressor cover
Tubular punishment racing 3" O2 housing
Recirculated Tial 38mm Wastegate
SBR new ported/high temperature ceramic coated manifold
Apexi full 3.25" GT exhaust
Extreme Intercooler's 10.5" race front mount
Short route 2.5" intercooler piping
Polished 2g throttle body/elbow
Custom built aluminum sheet metal intake manifold
FP 4" aluminum intake with K&N 4" cone filter
Tial 50mm Blow off valve
GM 3" MAF
MAF translator
Greddy turbo timer
All emissions removed
Powder coated valve cover
Stainless steel manifold shield
Full 4 piece Polyurethane motor mounts
Stainless brake lines
Slotted rotors
Stainless clutch line
NGK wires
All new rubber bushings in the suspension/ new dust boots
Transmission:
Shep Stage 3 built tranny which includes:
# New 1-2 Fork
# New 3-4 Fork
# New Shep Trans Spec 2nd Gear
# New 1-2 Hub/Sleeve kit with Double Synchro Rings
# New 1-2-3-4- 5-R Synchro Springs
# New 5th Gear Synchro Rings
# New Input, Output, and both Drive Shaft Seals
# New Input Shaft Bearings
# New Intermediate Gear Bearings
# New Roll Pins
# New End Nuts
# New Center Diff Side Shims
# New Nylon Shifter Pad
# Shims for setting preload
# Upgraded Torrington Bearing
# Bead Blasted Case
# 4 Spider Center Differential
# Heavy Duty 3-4 Conversion
# Heavy Duty Shift Rails
# Transmission filter upgrade
# Upgraded Rare Earth Magnet
SBR 4000 clutch
ACT Streetlite flywheel
All Redline gear oils/tranny fluids
Fuel:
Walbro 255 lph high pressure in-tank pump
Aeromotive FPR
FIC 1000cc injectors
SBR Stainless fuel lines
4 gauge fuel pump wiring
Tuning:
DSMLINK V2
PLX M500 wideband wired into DSMLink/also has digital readout
Apexi AVC-R digital boost controller
Autometer cobalt boost gauge
Autometer ultralite oil pressure gauge
2 gauge pillar pod
Shift light
Full leather interior (power driver's seat)
6-disk CD changer
Kenwood components
Pioneer door speakers
I may be forgetting some stuff, email me at XxGSXRATEDxX@gmail.com for any questions.
Pictures:
http://img260.imageshack.us/my.php?i...mg10601lq1.jpg
http://img186.imageshack.us/my.php?i...mg10611ck2.jpg
http://img68.imageshack.us/my.php?image=img1065hr1.jpg
http://img168.imageshack.us/my.php?image=img1075co4.jpg
http://img266.imageshack.us/my.php?image=img1070yw8.jpg
Price:14000, OBO
JE forged pistons
Revised 3g lifters
Bronze valve guides
New oem water pump
New oem timing belt
Turbo parts:
GM 3" MAF
MAF translator
Greddy turbo timer
Slotted rotors
NGK wires
Transmission:
# New 1-2 Fork
# New 3-4 Fork
# New Roll Pins
# New End Nuts
# Bead Blasted Case
SBR 4000 clutch
Fuel:
Aeromotive FPR
Tuning:
DSMLINK V2
2 gauge pillar pod
Shift light
6-disk CD changer
Kenwood components
Pictures:
Originally Posted by krzykrl96
just a question car says gs on the back not gsx?
man, i sold my 2g GSX ('97) ... Completely built with a 60-1. ON pump, 489 whp, and i only got $8600 for it. :-( ... perfect condition too. good luck with yours. god knows i miss my dsm....
4G63 FTW !!!!! 6-bolt that is... haha
