WTT: Mustang for LS1
WTT: Mustang for LS1 *pictures added
I have a 1988 Mustang, Street car, put about 100 miles on all the parts listed below. let me know if you are interested.
302 .030 over
Trick Flow 11-1 pistons
Trick Flow Twisted Wedge Heads
Trick Flow Intake
Trick Flow Roller cam w/1.6 rockers
Trick Flow Valve Covers
Ceramic coated long tube headers
3 inch Ex w/Flowmaster 40's
MSD 6AL Box
MSD 2 Step
MSD Billet Dist
MSD Blaster 3 Coil
MSD Super Conductor Wires
NGK Platinum Spark Plugs
BBK Cold Air intake w/K&N
BBK 75MM Throttle body
BBK Adj Fuel Press Regulator
30Lb injectors
Walbro 255
SCT Custom Burned Chip w/upgraded computer
Art Carr 4000 Stall
Art Carr Competition C4 Trans w/Rev Man valve body/trans Brake
Deep Tranny pan
TCI Trans Shield
Driveshaft Loop
B&M Pro Ratchet Shifter
Trick Flow EFI Nitrous Kit
Motive 3.73 Gears
Weld Draglites, Skinnis/Hoosier 26/9's
Cervini's Hood
Drag Springs front and rear
Adjustible Upper Control Arms
Tubular Front K Member
Poly Engine Mounts
Autometer Fuel/Nitrous/Tach Gauges
mini starter
302 .030 over
Trick Flow Intake
MSD 6AL Box
MSD 2 Step
MSD Billet Dist
MSD Blaster 3 Coil
30Lb injectors
Walbro 255
Art Carr 4000 Stall
Deep Tranny pan
TCI Trans Shield
Driveshaft Loop
Motive 3.73 Gears
Cervini's Hood
Poly Engine Mounts
mini starter
