Western Members CA, AZ, NV, UT, CO, NM, HI
Need help asap
Old Oct 30, 2008 | 12:25 AM
DirtyBird310's Avatar
Default Need help asap
well i dont know what happen but went to start the car and it didnt crank over, everything came on lights gauges etc but when i tryed to turn on nothing. Anybody go thru this
Old Oct 30, 2008 | 12:26 AM
1badchicken's Avatar
Default dead car
Sounds like the starter is dead!!!!!
Old Oct 30, 2008 | 12:37 AM
60ftkiller's Avatar
Does it click like hell when you hold the key in the start position?
Or maybe security? Try locking and unlocking the car? If not then most likely the starter..
Old Oct 30, 2008 | 12:39 AM
noclicking at all but when i pop the clutch it comes right on
Old Oct 30, 2008 | 12:45 AM
60ftkiller's Avatar
Starter then. Take it out and get it tested at autozone just to be sure.
Old Oct 30, 2008 | 12:46 AM
Damn guess im not going to work tomarrow
Old Oct 30, 2008 | 12:50 AM
60ftkiller's Avatar
24hr autozone homie. Should be one somewhere decently close.
Old Oct 30, 2008 | 01:35 AM
ubn_jacked@hotmail.c's Avatar
just 1 thing u might wanna check also is the starter relay.... switch it with one of the other relays in the same relay box =) <^^^^ if the stater isnt the issue...., but it doesnt hurt to try it out b4 you go and pull out ur starter =)
Old Oct 30, 2008 | 01:37 AM
60ftkiller's Avatar
You mean the fuse?
Old Oct 30, 2008 | 09:55 AM
maverick32's Avatar
hey what up man, i had a similar weird episode too. it was after work and i turned on my car but it was idleling at 500rpms so it had a really rough idle. i would rev a little and it would go down and settle at 500rpm. so what i just did is turned it off and waited for a few minutes. Then after the few minutes i turned it on and started fine. Well still kind of rough but it progressively got back to its normal idle. i was like this......
Old Oct 30, 2008 | 10:12 AM
Yeh it wont crank over at all so i am going to check the starter and the relay and if that is not it then the alternator cant be the battery i got juice going into the car
