Western Members CA, AZ, NV, UT, CO, NM, HI
h/c install tomorrow
Old Nov 27, 2008 | 04:33 PM
jsteele90's Avatar
Default h/c install tomorrow
myself and nick123 are gonna be doing the h/c install tomorrow in temecula if anyone wants to lend a hand or just come by and bs. also if you have a 3 jaw puller or know where to get a decent one let me know
Old Nov 27, 2008 | 04:44 PM
MaroonLS1's Avatar
**** i work. itd be a good learnign experience
Old Nov 27, 2008 | 07:30 PM
jsteele90's Avatar
ttttttt
Old Nov 27, 2008 | 07:47 PM
1BDHWK's Avatar
I don't have time tomorrow, but I do have a 3-jaw puller if you need to use one. I have done H/C at least 15-20 times on LS cars. I used to change H/C combo's on my drag car like most people change radio stations. If you have questions, let me know. Shoot me a pm if you need to puller.
Ben
Old Nov 27, 2008 | 08:09 PM
ss.slp.ls1's Avatar
If I wasn't already installing a cam tomorrow, I'd come and lend a hand. Bad timing.
Old Nov 27, 2008 | 08:10 PM
MrElectric03's Avatar
I used the autozone puller but I pulled the engine.
Old Nov 29, 2008 | 02:21 PM
jsteele90's Avatar
the job is done took us 14 hours. 2 trips 2 autozone and one trip to jack in the box. biggest PITA was removing and installing the harmonic balancer. car sounds great just enough of a lope to let you know it has a cam but nothing that will attract to much attention.
Old Nov 29, 2008 | 02:43 PM
1BDHWK's Avatar
That first time the bolt and balancer come off, your right, it sucks!!! It will be easier now.
Congrats on the H/C completion!!!!
Old Nov 29, 2008 | 03:31 PM
01SOMSS!'s Avatar
congrats!cant wait to se it.
Old Nov 29, 2008 | 03:32 PM
jsteele90's Avatar
thanks ben i have your puller and one of your cheater bars with me. i left the other one in temecula at my buddies house where we did it at. is it cool if i bring it all to you monday after work?
Old Nov 29, 2008 | 03:37 PM
1BDHWK's Avatar
NP. Enjoy that Heads and Cam!
Old Nov 29, 2008 | 03:45 PM
jsteele90's Avatar
ill enjoy it alot more after i get it tuned then its on
Old Nov 29, 2008 | 04:24 PM
1sikZoh's Avatar
how big is that cam you put in there?
Old Nov 29, 2008 | 04:31 PM
jsteele90's Avatar
just a baby cam. 224/224@112 mti c2
Old Nov 29, 2008 | 04:37 PM
cruiSSin LS1's Avatar
congrats on the h/c install!!! u going to CMS to get it tuned?
Old Nov 29, 2008 | 04:43 PM
jsteele90's Avatar
of course
Old Nov 29, 2008 | 04:53 PM
1sikZoh's Avatar
might as well get spray before you get it tuned and do it all at once.
Old Nov 30, 2008 | 01:47 PM
jsteele90's Avatar
probably a dumb question but would the h/c install throw off my tranny shift points and torque converter lockup?
Old Nov 30, 2008 | 01:55 PM
BigDaddyBry's Avatar
I'm pretty sure those are set in stone, till programmed differently.
Old Nov 30, 2008 | 02:17 PM
BobDoLe's Avatar
if you make more power, yeah it will slip a little more and throw off the shift points. just throwing on an LS6 intake caused me to hit the rev limiter, so i had to drop my shift mph a little - but that was because it was an SRJ LS6 intake.
your misfire tables were probably desensitized for the converter, but may need a little more adjustment for the cam so that it doesn't cause the lockup to disengage.
i'm sure cms will be able to take care of it for you.
By Brett Foote | 2026-06-04 05:00:17
