Western Members CA, AZ, NV, UT, CO, NM, HI
need help with weld skinnies?
Old Dec 4, 2008 | 04:25 PM
CESARZ's Avatar
Red face need help with weld skinnies?
i have some weld prostars 15x3.5 they do not move front or back because they rub on the caliper?so should i grind the caliper???????any body with front skinnies with similar problem?thankyou
Old Dec 4, 2008 | 04:26 PM
ZexGX's Avatar
My sources say Yes. You can run spacers which will require less grinding too (probably need longer studs with the spacers). Bogarts are supposed to be direct fit, but that doesn't help much now...
P.S. My source is the search button ^^^^
Old Dec 4, 2008 | 04:51 PM
krazy4's Avatar
Yeah, you have to grind.
I believe the only wheels that allow you to get away with no grinding are the bogarts and the centerline convo pros.
Old Dec 4, 2008 | 04:57 PM
LS1BLKSS's Avatar
Banned Village Idiot
if you have a spacer you don't ahve to grind ****
Old Dec 5, 2008 | 04:08 PM
Dan's Avatar
Dan
I run spacers with mine, no grinding, no longer studs. They came with the tires when i bought them(used), So not sure where you can get them
Old Dec 5, 2008 | 06:11 PM
SS MPSTR's Avatar
No grinding at all with spacers, and I'd recommend you get longer ARP wheel studs.
Old Dec 5, 2008 | 07:04 PM
1SLO6's Avatar
THIS FOOL!!! u know skinnies aint gonna make u faster than me...... Whats up Cesar u have to run longer ARP wheel studs with a small spacer. R u running LS1 brakes???
Old Dec 8, 2008 | 07:08 PM
CESARZ's Avatar
no they are the stock lt1 roters and i do have a spacer is about 1/4 inch and still will not move?
Old Dec 8, 2008 | 07:54 PM
SS MPSTR's Avatar
you need 7/16" spacers and longer wheel studs.
Old Dec 11, 2008 | 12:49 PM
CESARZ's Avatar
what if i just install spacers with no longer studs
Old Dec 11, 2008 | 12:57 PM
beezer1519's Avatar
i don't thing you'll be able to get the lug nutz on there??? i believe that's why they run longer studs
Old Dec 11, 2008 | 01:05 PM
TRANS(AM's Avatar
that's dangerous
Old Dec 11, 2008 | 01:19 PM
01SOMSS!'s Avatar
hmm. bryce runs spacers on his.
Old Dec 11, 2008 | 01:24 PM
1_bad_TA's Avatar
I have weld draglites on my ta. I run a 5/16th spacer with the ARP 3.25 studs. You can get a 5/16 spacer from Autozone, Murray's, Advance Auto, etc etc. The studs i'm sure you could get from any sponsor on here.
