Western Members CA, AZ, NV, UT, CO, NM, HI
My Motor Is Toast
Old Feb 20, 2009 | 08:39 PM
383lt1impala's Avatar
i would but but 12.5 compression and psi dont mix.
Old Feb 20, 2009 | 08:45 PM
C5natie's Avatar
You didnt feel the car weird or miss with a piece of cylinder missing? Thats crazy. Time to go bigger. 427-440?
Old Feb 20, 2009 | 08:46 PM
XpEdItIoUs's Avatar
Thats not stock compression buddy, are you going to buy my turbo kit. I really want to get that pulley.
ZexGX's Avatar
pix or it didn't happen!
jk.
Old Feb 20, 2009 | 08:50 PM
XpEdItIoUs's Avatar
Thats why i think it didn't happen when i owned the car, the previous owner had n2o on the car. the piston ring is still sealing the cylinder only a peice of the top corner is missing. I would of heard a peice that big brake off and no to mention my turbine would of been damaged and its mint.
Old Feb 20, 2009 | 08:56 PM
nothing in the motor is stock,
Old Feb 20, 2009 | 09:00 PM
XpEdItIoUs's Avatar
Here is the pic
Old Feb 20, 2009 | 09:01 PM
ss.slp.ls1's Avatar
Here is the pic
Is the cylinder repairable, or is the block toast?
Old Feb 20, 2009 | 09:03 PM
XpEdItIoUs's Avatar
Not a scratch on the cylinder wall, its a rebuildable block. Even the cumbustion chamber on the head was flawless its weird .
Old Feb 20, 2009 | 09:08 PM
ss.slp.ls1's Avatar
Did you read my post on the other page? Pic up a iron 6.0 shortblock.
Old Feb 20, 2009 | 09:13 PM
hmmmm i have a 6.0 shortblock..............
Old Feb 20, 2009 | 09:14 PM
  #32
XpEdItIoUs's Avatar
Yes but Im unemployed due to the fucked up economy
Old Feb 20, 2009 | 09:16 PM
  #33
XpEdItIoUs's Avatar
Nice jose.
Old Feb 20, 2009 | 09:24 PM
  #34
tripblackls1's Avatar
a piece that big would have definitely had some damage that motor probably has been torn apart after this has happened and they probably reuse that piston to be cheap *** holes
looks even like they cleaned up the missing part of the piston because
pistons will usually melt not just chip apart which would explain why there is no damage to block or head and if it was on n20 this sounds like the most likely story then the aholes cleaned it up put it back together and sold it to you
just my guess i could be complety wrong
Old Feb 20, 2009 | 09:27 PM
  #35
XpEdItIoUs's Avatar
Exactly what i was thinking, I purchased this car 5 years ago. Back then cars with the same milage where going for 10k i got it for 6k now i know why. They just wanted to sell it fast, now i know the reason
Old Feb 20, 2009 | 09:31 PM
  #36
camarojunky74's Avatar
shitty man.
Old Feb 20, 2009 | 09:35 PM
  #37
CaliforniaBoy5's Avatar
Nice sig luke,
Sorry to hear about that Ivan. any buyers on the turbo kit yet?
Old Feb 20, 2009 | 09:36 PM
  #38
Red98a4SS's Avatar
from what i have heard is ls1 pistons do chip like that and usually the piece that breaks off melts away without causing major damage not all the time but this doesnt surprise me my buddies 99 n20 car had the same chip with no damage
Old Feb 20, 2009 | 09:38 PM
  #39
think about it ivan, you and almost ryan's motor took a **** the same exact way. irony??? or sabotage??? lol
Old Feb 20, 2009 | 09:39 PM
  #40
98BlkFormula's Avatar
lol the diff is that if he put the heads back on the car will still run like it did 2 days ago...
