motor is fried.....agian.
If this guy is legit this is a good deal good luck w/ your search
http://losangeles.craigslist.org/lac...060052488.html
You can mod them in exactly the same way you mod a LS1. Everything is compatible. It's basically a iron LS1 with the same stroke, smaller bore. Once you put a cam, heads, intake...the only thing that will be different is the displacement. Plus it's iron so you can build it to take some abuse, and it can easily be bored out to a 5.7.
#35
Good looking out SRJ..
#39
Well that's good to hear because I was planning on using the 503 that's what I wanted to get. Also when I think big cam I think of something like cu has in his car where it's cammin so bad that it sounds like it's barely running at idle LOL
#40
its not your fault man. my dumb *** was the one who chose to go run with you instead of just chillin at the track. its all good though. if i dont get an ls car im gonna have a decently fast lt car when im done with it.
