Western Members CA, AZ, NV, UT, CO, NM, HI
rack and pinion
Old Apr 19, 2009 | 06:30 PM
camaro19973's Avatar
Default rack and pinion
what symptoms can i look for when the rack and pinion is going out. ask this cuse mine is hard to steer but the thing is i just changed the power steering pump yesterday, and now its worse all the lines are i the place they need to be. when i drive like the car steers hard to one side and when i try to correct it it does the same thing to the other side need help on this thx.
Old Apr 19, 2009 | 07:19 PM
pweterss's Avatar
what car ,year?
Old Apr 19, 2009 | 07:29 PM
sorry its a 99 ss
Old Apr 20, 2009 | 12:41 AM
DirtyBird310's Avatar
Is there any fluid leaking from the rack?
Old Apr 20, 2009 | 10:44 PM
ZexGX's Avatar
Have you checked your alignment??
Old Apr 20, 2009 | 11:13 PM
no fluid leaking and yes my alignment is getting messed up driver side tire is getting worn
Old Apr 21, 2009 | 12:17 AM
ZexGX's Avatar
Where are you located? If I were you I'd take it to a shop. Here's something you can do yourself: jack up the front of the car, and wiggle each wheel with your hands. Twist them (towards you and away from you) left/right and top/bottom. There should be little to no play.
