Western Members CA, AZ, NV, UT, CO, NM, HI
Installing subframe connectors
Old Apr 30, 2009 | 03:10 PM
Sommer86's Avatar
Default Installing subframe connectors
Anyone know a good place to get my subframe connectors installed here in the san Fernando Valley? They're just sitting here looking pretty, but I have no idea who to go to that's installed these before.
Thay are the weld-in UMI subframes so i'd like someone experienced.
Thanks!
Old Apr 30, 2009 | 04:09 PM
ConElite's Avatar
I have the box ones from UMI. Got them welded at some shop here in SGV for $40.
Old Apr 30, 2009 | 04:29 PM
Sommer86's Avatar
^^Nice, got an address or name?
Old May 1, 2009 | 02:04 PM
ROCNDAV's Avatar
Yeah, I'd like to know too. I have mine bolted in, but want them welded in.
Old May 1, 2009 | 03:49 PM
ss.slp.ls1's Avatar
Any exhaust shop can hook you up for cheap.
Old May 1, 2009 | 06:08 PM
383lt1impala's Avatar
But make sure they know how to weld and not just do a lot of tacks.
Old May 1, 2009 | 07:45 PM
Sommer86's Avatar
I just want someone that knows how they are to be installed. Like if the car has to be under load, or the torque specs. or where they get welded to, etc.
Old May 1, 2009 | 07:52 PM
ss.slp.ls1's Avatar
Pretty sure you'll have to be on a ramp style lift (not a 4-point) to be able to get you up in the air and still be able to install the SFC's. The posts of a 4-point lift would likely get in the way of where the SFC's go (Just guessing). Then you know the car will have the SFC's welded on with the suspension loaded. It should be easy to see where they go and what need to be welded.
Here's some pics to help:
http://www.bmrfabrication.com/instructions/sfc001.htm
More pics (bottom of page)
http://www.umiperformance.com/2000?category_id=129
Old May 2, 2009 | 06:25 PM
SUCK MY SS's Avatar
i can do em... im in pasadena
Old May 2, 2009 | 07:10 PM
Sommer86's Avatar
Right on, thanks shant!!
Old May 2, 2009 | 07:31 PM
SUCK MY SS's Avatar
no prob... hit me up whenever 626 354 5526
Old May 2, 2009 | 08:02 PM
MrElectric03's Avatar
I can tell you from experience thats a bad idea, guy at an exhaust shop said he would weld in my SLPs and did a **** job, incomplete welds, looks like bird **** and he used bolts to space them down away from the fuel lines so they didnt even make full contact.
One of these days im cutting them off and either doing it myself or taking em to CMS.
Old May 4, 2009 | 09:11 AM
thegooseman's Avatar
Dyno Don is a terrific welder. He pretty much does all of our thridgens but he's down in Orange. If you want experienced guy to do it, then its worth the drive.
Don Lorentzen
1030 W. Hoover Ave.
Orange, CA 92867
(714) 633-5168
Engine rebuilding, Trans rebuilding, Subframe Connector welding, Exhaust specialist, Rear end specialist, Custom chips, Carb/TBI/TPI.
Old May 4, 2009 | 01:26 PM
CaliforniaBoy5's Avatar
Don Lorentzen
1030 W. Hoover Ave.
Orange, CA 92867
(714) 633-5168
Thanks for the info!
Old May 4, 2009 | 01:31 PM
ss.slp.ls1's Avatar
Dyno Don is who welded on Mike's (3rd Gen Mike) SFC's. He did a good job.
Old May 4, 2009 | 10:12 PM
PwrHngryLT1's Avatar
i say no to the exhaust shop from experience...like MrElectric says. I also need to get my subframes welded.
Old May 5, 2009 | 02:51 AM
-98-Z28-Darkness-'s Avatar
how much of a difference is welded to bolted in stiffness?
Old May 5, 2009 | 11:18 AM
ss.slp.ls1's Avatar
x2. I'd like to know.
Old May 5, 2009 | 01:34 PM
i'd personally buy bolt-in SFC and have the ability to get them welded later
Old May 5, 2009 | 01:39 PM
ss.slp.ls1's Avatar
I have SLP 3 point, bolt-in SFC's
