Cluncking rear!
I have had the same control arms for maybe just under 2 years.
What Spacer? I know there are the bump stops right by the disk to stop the axle from going higher in the car, but there are spacers there? I have never seen them?
If you take off the rear tire look just above the rotor under the body and you will see the rubber bump stop, usually they have about a 3/4 to 1" aluminum spacer.
I know where the bump stop is, and no there is no Spacer there. I dont believe ANY f-body came stock except maybe the SLP edition ones bc SLP is the company that sells those spacers.
If you can find your stock arms ill go get them.
Thats strange, my WS6 had them and my parents SS has them.
Ill take a look for them today and let you know if I find em.
