Western Members CA, AZ, NV, UT, CO, NM, HI
ls7 lifter and pushrod ?
Old Aug 3, 2009 | 04:01 PM
MJs1FastSS's Avatar
Exclamation ls7 lifter and pushrod ?
ok so looking on tech there are some mixed reviews ...
will the standard 7.4" pushrods be fine to run with new ls7 lifters? or are they too long?
i dont want oil pressure issues, nor have to get another set of ls7's before i see oil issues
or would a 7.35" be best....
how are your ls7 lifters holding up?
Old Aug 3, 2009 | 04:17 PM
383lt1impala's Avatar
Its best to measure.. Its quite easy accually. And yes the 7.4 are too long since the ls7 lifters go less in into the lifter than the ls1s. I have 7.4s in mine and they are too long ill measure mind before the initial start up.
Old Aug 3, 2009 | 04:25 PM
wickedbluess's Avatar
I'm running ls7 lifters and 7.4 harden push rods with no problem!
Old Aug 3, 2009 | 05:00 PM
MJs1FastSS's Avatar
how long have they been on raul?
Old Aug 3, 2009 | 06:00 PM
About 100 miles. Moe also has same set up for a long time with no problems
Old Aug 3, 2009 | 06:28 PM
haighter's Avatar
They will fit stock heads as long as they are not milled.
Old Aug 3, 2009 | 06:34 PM
I would measure in your case ms4 + 2.5s . I'm just running stock ls6 heads
Old Aug 3, 2009 | 06:41 PM
ss.slp.ls1's Avatar
Measure, and then measure again.
Old Aug 3, 2009 | 06:45 PM
haighter's Avatar
As long as the base of the cam lobes are not off then you are ok. Or the head is not milled then you are ok. You should have .05-.09 of an inch for the lifters to work right witch is between one too two turns on the rocker when there is no more slack in the push rod then torque to 22 lbs. You have to check to see if you make between one to two turns on the torque rench then you are in the ok. You can only get push rods in eather 7.4-7.35-7.30-7.25 ect... So thats why it is between one too two turns.
Old Aug 3, 2009 | 06:47 PM
haighter's Avatar
Any questions?
Old Aug 3, 2009 | 06:57 PM
MJs1FastSS's Avatar
thanks for that
Old Aug 3, 2009 | 08:47 PM
SUCK MY SS's Avatar
if you are merely changing out the lifters from ls1 style to ls7, no pushrod length change needs to be made..
however if you have changed any components, such as going from stock to performance cam (smaller base circle), milled heads, thinner head gasket, then yes, pushrod length needs to be checked...
Old Aug 3, 2009 | 08:52 PM
MJs1FastSS's Avatar
gotcha....yeah going with ms4 and PRC ls6 stage 2.5's or PRC 215cc CNC Ported LS Cylinder Heads...not too sure yet.....? my b-day is comming fast up and this will be a great present from the GF... so just gathering info so i can tell her what i want
I need to check it out
Old Aug 3, 2009 | 09:01 PM
MJs1FastSS's Avatar
i will be running stock bottom end for now..... fast 92/92 and a little spray
Old Aug 4, 2009 | 03:01 PM
haighter's Avatar
I would like to add... That if you are going to be going with that cam you need to check piston to valve! If I'm not mistaken you will have PTV issues with stock pistons.
Old Aug 4, 2009 | 03:44 PM
ss.slp.ls1's Avatar
Yeah, most have to flycut the pistons.
Old Aug 4, 2009 | 05:21 PM
Tsp can make the 2.5s so that you don't have to fly cut as much from what I've read. But you will have
To fly cut the pistons if I'm not mistaken also.
