Western Members CA, AZ, NV, UT, CO, NM, HI
Motor taking a shit
Old Nov 19, 2009 | 11:22 AM
carbonfiberbird's Avatar
Default Motor taking a ****
Well after some diagnosis for my cars rough idle, I found out that my motor is worn. After much research on 355 set ups I have decided to do an lsx/t56 set up, but I was planning on doing that mid next year. I really didn't want to dump money in a setup that I wont use but it looks like that what I'm gonna have to do. So my plan is to just do a stock rebuild on a 350 I have and just cam it which should make my car move pretty good(mid 14's is not bad for now)
Old Nov 20, 2009 | 11:13 PM
Jeremy 92 RS's Avatar
A G92 equipped 90-92 Speed Density 305 TPI matched to a T5 is capable of high 13's with just full exhaust and tune...so, I think its safe to say you'd definitely be hitting at least 13's in the 1/4 with a 350 TPI, regardless of your car being an 89 with a MAF.
Do some DIY porting on the heads and intake system and throw a decent cam in there to get you by. Will be a FUN street light to street light car. Besides, if you had anymore power, you'd probably blow that T5 to bits. Is your trans World Class or Borg Warner?
Old Nov 20, 2009 | 11:32 PM
Really? **** YEAH! How much whp do you think I'll make? I was guessing around 250-260, pretty accurate? Its a WC t5 I'm not too worried about it, it should easily last a year. I'm not putting any sticky tires on it or anything. Mid 13's possible? I have 3.73s and I'm gonna put a full exhaust and do some head work with a decent cam too. I'm still researching what exactly I have to do for the 350 swap, I pretty much know what to do now.
Old Nov 20, 2009 | 11:43 PM
XpEdItIoUs's Avatar
Are you sure it's taking a ****? Maybe it just has really bad "Gas".
Old Nov 20, 2009 | 11:49 PM
Good. I had a 355 TPI mated to a WC T5 and I was NOT nice to it to say the least...and it held up until the day I got rid of it. The motor performance wise was mostly stock except mild porting to the heads/intake system and full exhaust with a baseline tune that was very off. Stock cam, 3.42 gears with a Zexel posi. It was fast for what it was. The person that built the car (Dyno Don from thirdgen.org) estimated it at about 250 to 260ish rwhp, but I never confirmed it. At the very, very least I know it was a high 13 sec car. Again, at the least. Cuz I had some good kills for a mostly stock 355. You're gonna have a cam and better gears, so i'd say if your expectations are only mid 13's and 260ish rwhp, im sure you'll be happy with the outcome assuming your part selection (esp. the cam) and mechanic work are in order.
Good luck though. At least yours is driving. My third gen is sitting in the driveway as a rolling chasis with the new motor and trans in the garage. But my setup is a little more complicated...
Your swap will be a snap. You really dont need to do anything...just drop in the 350 and tune.
Old Nov 21, 2009 | 04:15 AM
ss.slp.ls1's Avatar
Why not buy my cammed LT1/T56 set up. You'll be in the 12's for sure.
Old Nov 21, 2009 | 10:26 AM
No money, I really want to! I'm thinking in about a year I want to start an lsx/t56 swap. I was gonna build up a 355 and 6 speed but after ALOT of research on the set up I figured it would be better to save just 1k more and go for the lsx swap.
Old Nov 21, 2009 | 01:24 PM
Soul TKR's Avatar
you could do and LQ swap... they are cheap and yield good power.
did I miss something? when did you TA get totaled?
Old Nov 21, 2009 | 03:52 PM
TPI TERROR's Avatar
lq4 swap .. with fbody accesories.
Old Nov 21, 2009 | 04:45 PM
Like 6-7 months ago
I'd rather just save up a the rest and just go for the ls1, I want my car to handle really good. If I drop an ls1 it will stay stock but I'm going to do everything I can to suspension and chassis, brakes too. I love autoX, SO MUCH FUN!
Old Nov 21, 2009 | 04:47 PM
My budget is 1k MAX for now. One of the reason I put my old wheels on my car so I would'nt have to buy new tires. Plus I like these wheels WAY more.
Old Nov 21, 2009 | 05:57 PM
TPI TERROR's Avatar
Like 6-7 months ago
im trying to save up for my front suspension and some ctsv brakes..
i wanna do the same.
Old Nov 21, 2009 | 06:03 PM
MSS91Z28's Avatar
Like jeremy said, you're going to have alot of fun with that 350 tpi setup until you get your ls1. In my first black 91 z' (jeremy's car now) I had a mildy cammed 350 tpi with exhaust, crappy 2.73 gears, and a sloppy shifting auto trans, and tune.
It ran an 8.9 @79 mph with a slipping 2.0 60' at irwindale...about a 13.7 in the 1/4. Had I ran with slicks I could have probably made that car run a 13.5 in the 1/4. Sounds like you'll have a similar setup but with a better tranny and gears so yes mid 13's are easily possible.
The guy I bought that motor from for that car said the motor put down 275 rwhp which sounds about dead on. So expect a number in that area with at least 350 rwtq. Just do your research and you'll be fine.
Old Nov 22, 2009 | 12:00 AM
Yeah for sure, for me after I went autoX I was hooked. Plus for what you have your car is ridiculously fast and you can put like 200k on your set up.
Damn that would be really nice! I'm just gonna drive my car till the motor starts making some noise then I'll send my 350 to get built, hopefully my motor will last just long enough that I could just go straight to the lsx swap, cuz I put like 4k on my cars a year on average so it may just last.
