Western Members CA, AZ, NV, UT, CO, NM, HI
Need help with my headlights!!!!!!
Old Dec 16, 2009 | 01:49 PM
hawk611's Avatar
Angry Need help with my headlights!!!!!!
Dose anyone know what could be wrong with my headlights, it stared doing this last night. I only dose this when i turn them off and when i lock the car with the remote and when i unlock it as well. I is there a module that is causing this or relay that i need to change out.
Old Dec 16, 2009 | 04:48 PM
ss.slp.ls1's Avatar
You need a new gear for the head light motor. Or I've heard you can remove them and flip them 180.
Old Dec 16, 2009 | 05:32 PM
LS1BLKSS's Avatar
Banned Village Idiot
you need a new gear its pretty cheap, my vette was ******* up like that, i replaced the gear, stock one is a cheap *** plastic one, get the brass one
Old Dec 16, 2009 | 07:34 PM
MrElectric03's Avatar
New gear in the headlight motor will fix it, you can take the linkage off and turn teh gear 180* but mine only lasted a week when I did that, the I went with the aluminum gear kit from ebay...
Old Dec 16, 2009 | 10:28 PM
0235SS's Avatar
tira tu putada a la basura... ha this ******, did u fix it?
Old Dec 16, 2009 | 10:56 PM
9802TransAm's Avatar
I put the brass gears in my car....they only lasted about 18 months before they wore down as well. Ended up getting a new motor from GM...it lasted about a year and now it's getting ready to go. Anyone know if temperature effects this at all? It was fine all summer, but it dropped to below 20 degrees last night and I had to pop it manually. Anyone know where to get any made out of a material that will last? The brass was just too soft and started to break down; any ideas?
Old Dec 17, 2009 | 10:41 AM
LS1BLKSS's Avatar
i would just stock up on those brass gears, those are pretty strong tho not sure why your breaking them, if the stock plastic lasts a few years the brass one should last a good couple years on top of that
Old Dec 19, 2009 | 02:54 AM
hawk611's Avatar
Thanks guys, i got the new gear today and i already installed it, i packed it with plenty of grease will see how long this brass gear will last me.
Old Dec 19, 2009 | 05:40 AM
Raptor_WS6's Avatar
the gears are made of plastic for a reason. i have heard that the brass one wear out the motor faster, how i dont know, read it a long time ago and dont remember.... there are def mixed reviews on the brass gear.... also sometimes that happens when the headlight has a bad ground
Old Dec 19, 2009 | 11:26 AM
CaliforniaBoy5's Avatar
I agree; why go with a brass gear when the stock gear lasted this long?
Old Dec 19, 2009 | 03:48 PM
LS1BLKSS's Avatar
reason is they were being cheap asses
