Torque Management Questions
There are various tables that control TQ management.
Max Torque RPM vs Gear
vs. RPM
Tip In Torque
Spark Retard vs. % Torque Reduction
Torque Loss % vs. Spark Retard
and then the two tables under TCS Method:
Retard vs. RPM
Aggressive Retard vs. RPM
What to do with what is dependent on what you are looking to do.
This was taken from HPTuners message board in reference to a truck, but the same applies in your vehicle for the most part.
http://www.hptuners.com/forum/showthread.php?t=23766
Engine, Torque Management, General:
Maximum Torque
RPM vs. Gear - Max out
vs. RPM - Max out
Max Torque
Max Torque - Max to 640
Tip In Torque - Max out
Trans Input Max - Max out
Trans Output Max - Max out
Front Axle Max - Max out
Front Propshaft Max - Max out
Rear Axle Max - Max out
Rear Propshaft Max - Max out
ETC Limits
ETC TPS Max - Max out
Spark Retard
vs. Torque Reduction - Zero out
Torque Loss %
vs. Spark Retard - Zero out
Engine, Torque Management, Abuse:
Drivetrain Abuse
RPM > - Max out
Speed < - Zero out
timer vs. Trans Temp - Zero out
Trans, Torque Management:
Abuse Mode
Enabled - Set to Disabled
RPM - Max out
TPS - Max out
Speed - Zero out
Torque Reduction
Normal - Zero out
Performance (aka Tow/Haul mode) - Zero out
I hope this helps!
