****VIDEO**** - Clutch SQUEAL Noise...
LS1TECH Sponsor
YES!
that's what's sooooo damn aggravating about it... I don't wanna know how much money I've spent on the labor alone in the R&R of the clutches and tranny. I've tried cheap clutches and I've tried $1500 setups... The car NEVER sees the track, and I drive it pretty damn conservatively. So I don't know where I'm going wrong.
I guess just the nature of the beast...![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
the monsters and textralias make the same noises.... they are all puck style clutches.... what do you expect when your applying a metal puck to a metal flywheel.... its going to make noise with being slipped.... otherwise the oem manufactures would use it on stock cars.... its a simply compromise you have to make.... if it was my car at the power level your at i would just install a ls7 clutch and call it a day... and enjoy stock driveability
yea... Good points. I do eventually plan on running a Midwest Chassis 9" but that won't be for a while. I suppose I'll run this one till it gives out on me, then figure out what I'm gonna do from there. I've just never heard anyone elses clutches sound like this, even as many car shows, and cruises I've been to, seems like mine is the only one...
Centerforce e-mailed me back on their thoughts as well....
Upon reviewing the video I can understand your concern with the noise. I’ve heard/experienced noises upon engagement of the clutch with the use of ceramatallic friction material, however, your vehicle seems to be slightly louder than the normal. The noise almost seems to be amplified by a tin sound which I’m uncertain of what is creating/amplifying the noise. Other than the noise, I don’t know that this would lead or cause a failure within the clutch. If this noise is something you can’t deal with and would prefer we inspect the clutch for abnormal wear or possible causes of excessive noise, you can contact us for a return number so we can evaluate the disc.
Wes:
So you painted your car Yellow now??? LOL![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
Why did you go such a aggresive Clutch when you dont have the tire or rear end to even support it? What do you have for tires? Bald azz Kumho's![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
That noise is not that bad. Now go get some GOOD TIRES then a rear end and let that Clutch do what it is supposed to do, 5K Launches that way a stock C5 wont beat you.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Why did you go such a aggresive Clutch when you dont have the tire or rear end to even support it? What do you have for tires? Bald azz Kumho's ![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
That noise is not that bad. Now go get some GOOD TIRES then a rear end and let that Clutch do what it is supposed to do, 5K Launches that way a stock C5 wont beat you.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#32
I was doing some research on LS1Tech because I'm loosing some coolant and I came across a thread from you, Wes in 2007. You were having to buy a new radiator but were low on cash because you just bought a clutch. LOL.. You have been dealing with this clutch issue for a while. I went with the SPEC 2+. It was cheap, has good drivability and it's good for 782 ft/Ibs of torque. (which I'll never see... LOL)
I hope you finally get it taken care of. Your car is too badass to be embarassed by unwanted noises...
#33
now that's funny stuff... you gotta send me a link to that thread. But yea, this is probably the 6th clutch I've had in the car.
To be honest I've heard SOOOO Many bad things about Spec clutches, I'd probably never go that route. I'm pretty convinced when I swap this one, depending on my mods at the time, I'll probably go Monster or LS7.
as far as my radiator, I ended up getting an expensive *** Be Cool one
No complaints, I like it, nice build quality and is about twice the size of the stocker, so cooling hasn't been an issue.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
lemme guess, your stock radiator cracked at the plastic area?
#34
strange thing about this it my custom six puck clutch had never made nosie, untill the past weekend i put a new motor in my car, my clutch had very little wear so i just put it back together(without new disc or resurfacing anything) and now it make similar (not nearly as loud) noise
maybe the noise has something to with flywheel/pressure plate surfaces??
did yours always make this noise or is this something that just started happening?
#35
#37
hmmm thanks guys, that makes me feel a little better. I just needed a video so everyone could see and confirm what I've been told. I just couldn't comprehend that this would be "normal" for a clutch to do ![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Ryne, I'll probably eventually spring for one of those Monster Clutches at some point... it's rough seeing as it'll be like my 6th or 7th clutch swap. It's getting old trying to find the right one. Glad you chimed in to ease my nerves on this particular noise...![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Like Myself and a few others said multiple times when you first had it in our car two years ago.... It is normal for that type of clutch and especialy when you try and drive it like that and not use it as a performace clutch and abuse it.
#38
alright... well I think this thread has come to a rock solid conclusion then. I need to beat the **** out of my clutch more often. ![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Thanks guys!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
P.S. CJ... I'm still trying to figure out what I'm gonna do with that flywheel on the mustang... I'll contact you when I have ALL the parts. I'm not in a hurry right at this moment so that's why you haven't heard from me...
Thanks guys!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#39
Hi, brand new member to this thread due to you clutch noise and great descriptive video. That is the exact noise my 1969 does. just rebuilt the motor aprox 425hp and not my first time installing a clutch???? I'm going to pull the gearbox and clutch out and do a through inspection. I'll let you know what I find....... however it looks like a week or so before I can get the time, maybe by July 15,2011.
#40
Well with my research, I've talked to a few members with the same problem and a few of them said it was their pilot bearing. They swapped it out and the problem was gone. I'm hoping to pull my tranny in the next month or two and see what I can find. Seems like the time this happened before (many years and clutches back) the needle bearing was toast causing this problem. I had a bronze bushing put in instead and the sound went away until the life of the clutch.
