Western Members CA, AZ, NV, UT, CO, NM, HI
does this mean i need alignment?
Old Apr 30, 2010 | 01:11 PM
TPI TERROR's Avatar
Default does this mean i need alignment?
been waiting for these the past 2 months.
i found a busted ball joint.
now i need new front tires and rear rotors.
Old Apr 30, 2010 | 02:09 PM
mannyman84's Avatar
Yeah u just need front toe adjustment. I don't think a bad ball joint would cause outer wear
Old Apr 30, 2010 | 02:10 PM
mannyman84's Avatar
Also check your tie rod ends
Old Apr 30, 2010 | 04:26 PM
1998LS1SS's Avatar
sick brakes!!!!!!!!
Old Apr 30, 2010 | 04:30 PM
-98-Z28-Darkness-'s Avatar
NICE!!! those brakes are huge! makes your 18's look smaller lol
need better tires to help with braking!!!
Old Apr 30, 2010 | 06:21 PM
Azrael's Avatar
LS1 Third Gen, holy **** dude that car is bad ***! Toe looks out with the outer wear...
Old Apr 30, 2010 | 06:56 PM
hlaalu's Avatar
Damn those look great.
Side note. Only the front of our cars need alignment right? For the rear it's pretty much just adjusting the panhard bar?
Old Apr 30, 2010 | 07:33 PM
F-BodyMind's Avatar
Good question..
Old Apr 30, 2010 | 07:45 PM
djsanchez2's Avatar
Of course you cant adjust the SOLID rear axle
The only way you can do any adjusting is to put on all adjustable parts.
Old Apr 30, 2010 | 08:08 PM
59 camaro's Avatar
looks good ay
Old May 1, 2010 | 02:00 AM
mannyman84's Avatar
Yeah only the front. Unless the caster is off if the whole diff would move for some reason. Front we might need a camber kit to adjust camber but toe is easly adjusted, but not be naked eye. U can do it yourself with a measuring tape
Old May 2, 2010 | 11:14 AM
TORCH FRC's Avatar
Yes. Sweet 3rd gen! Those V brakes and the color are really nice.
Old May 2, 2010 | 08:32 PM
TPI TERROR's Avatar
thanks man only few people noticed. lol
