custom wiring?
I can do the wiring for you. You can drill and tap the head to screw in the stock 3rd gen temp sensor (I've also read you can use a '98 LS1 temp sensor - haven't verified that). Alt gauge should still work. For the oil pressure gauge, you'll need to use an adaptor to screw the 3rd gen oil pressure sensor into the back of the LS1 block. The tach will work if you buy a Baker Electronics adapter box. For the mechanical speedometer you can buy a signal converter box. Fuel gauge will still work if you retain the stock fuel tank/fuel pump assembly and upgrade the pump.
you did this with a stock third gen dash? I'm not a fan of the 4th gen dash swaps, plus i dont wanna deal with taking it all apart.
Using a butane heated knife to trim the gauge cluster cavity.
Gauges in and wired up.
