Western Members CA, AZ, NV, UT, CO, NM, HI
need some guidence from the locals.....
Old May 24, 2010 | 10:02 PM
kornerz's Avatar
Default need some guidence from the locals.....
https://ls1tech.com/forums/pontiac-g...-cheap-hp.html
Old May 24, 2010 | 10:03 PM
kornerz's Avatar
thanks in advance
Old May 25, 2010 | 02:06 AM
jugz ss's Avatar
what are mods on the mustangs?
Old May 25, 2010 | 02:30 AM
kornerz's Avatar
aje front end, th400, coil overs, 1 3/4 long tubes, tr224 cam, patrion springs, nx kit
Old May 25, 2010 | 02:34 AM
00MaroonZ28's Avatar
he means the ones you are running
Old May 25, 2010 | 02:44 AM
kornerz's Avatar
my bad, its kinda late. One is a bolt car on the bottle and the other has a stroker.
Old May 25, 2010 | 04:19 AM
Wicked_muscle's Avatar
If I had my drive shaft in, I'd rape em both for you. Dry or wet shot are you planning?
Old May 25, 2010 | 09:48 AM
kornerz's Avatar
its wet, i dont think ima do it now. Its not worth going lean. I might just get a dyno tune and run it n/a
Old May 25, 2010 | 05:41 PM
djsanchez2's Avatar
Toss on a 125 and call it a day. 150 is the "safe" limit for a LSx on the stock tune, anything more will need plugs and a tune.
Cam only, 200 shot
http://www.youtube.com/watch?v=vuLwJG5yEKk
TRMIN8TR ran a 200shot/MS4 combo when he was 6spd.
http://www.youtube.com/watch?v=0mWDU5HI07Y
Old May 25, 2010 | 11:07 PM
jugz ss's Avatar
Yeah thats what I meant
OP.where are you located sounds like you need back-up
Old May 26, 2010 | 09:21 AM
kornerz's Avatar
im in the san fernando valley. We will be runninf them at california speedway on june 5th. Im getting a dyno tune friday morning, hopefully that helps
Old May 26, 2010 | 01:41 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i have seen stock motors with stock tunes +100 shot blow up
i have seen stock motors with stock tunes +200 shots live
my suggestion is get it tuned right, eliminate that variable that may cause failure, i wouldnt trust what someone tells you on hear, they arent going to pay for your motor when/if it blows up
