Western Members CA, AZ, NV, UT, CO, NM, HI
need help srj!!! tpi keeps overheating??
Old Jun 19, 2010 | 05:21 PM
MrElectric03's Avatar
Originally Posted by dreemurY2K SS
ok the guy just called me back..
he said i need a breather box or to put stock valve covers back on there, to replace the map sensor cuz it could have been damaged, an that i have a leak on my tb.
that if the compression keeps coming out to take it back...
does this sound correct??
an he says that i have a wrong temp sensor
It makes sense about the coolant temp sensor...that didnt even cross my mind
Old Jun 19, 2010 | 05:23 PM
dreemurY2K SS's Avatar
but i still think thats not a why the damn hose expands an the coolant in the reservoir tank is boiling
i honestly think those gaskets r backwards
Old Jun 19, 2010 | 05:31 PM
what about that of the breather box crap
Old Jun 19, 2010 | 05:40 PM
Sounds kinda like BS but I cant see what you have so its tough to say. If alot of pressure is coming out of the breather the rings could all be turned with the gaps in the same spot but rings will spin so its a little tough to say.
Old Jun 19, 2010 | 06:08 PM
XpEdItIoUs's Avatar
Im wondering what SRJ has to say
Old Jun 19, 2010 | 06:36 PM
lowerthanyou00's Avatar
Probably to put his ls3 in it. haha jk
Really id start a compression/leakdown test.
Old Jun 19, 2010 | 06:57 PM
also u shud do a compression test on ur coolant sytem
Old Jun 19, 2010 | 09:16 PM
TPI TERROR's Avatar
Id probably hook up a temp gauge directly to the side of the head to get a accurate reading.. maybe those mailbu fans aren't enough.. how are the fans set up? Where is the leak coming from? There is also a proper way to check timing by unplugging a est wire idk what color it is
ss.slp.ls1's Avatar
LOL, I didn't see this thread until now. Hopefully you got your issues figured out.
Old Jun 19, 2010 | 09:20 PM
TPI TERROR's Avatar
Post on thirdgen.org
Old Jun 19, 2010 | 09:28 PM
ok check it out..
this ******* didnt rebuild the 350 like we had agreed on instead a 305 accordingly he bored it out .030 over.
we agreed he would put a hot cam in it, i was looking at the cam that was in there an its this
10066049 which is a stock cam.
which is a l98 stock cam
CAM 88-89 L98 10066049 In/Exh Dur@.050" 207'/213' Lift (w/1.5) .415"/.430" LobSep 117'
http://temp.corvetteforum.net/c4/vader86/cam.html
he says there is no vaccum that the xr276 i put in is to big for it, and isn't producing vaccum.
if he didn't even change the cam, why should i believe that he even did bore it out an do everything rite??
its not a damn 350 didn't put the hot cam!!!
so what the hell did he do??
maybe thats not even my stock block, since i gave it to him exchange for the 350 an some cash..
this guy is full of crap
Old Jun 19, 2010 | 09:32 PM
  #32
so what i have is a 305 maybe bored .030 over with a xr276 comp cam with lol
wow aint this some bs lol
srj i should have bought that lt1 with the t56 of you
Old Jun 19, 2010 | 09:33 PM
  #33
3.8redbird's Avatar
My tpi never gets over 180 in south texas heat.
are they stock heads?
When I first got my car running my fans werent working but you said u had it rigged to a switch right?
Old Jun 19, 2010 | 09:38 PM
  #34
TPI TERROR's Avatar
looks like your going to need a new mechanic.
Old Jun 19, 2010 | 09:58 PM
  #35
yessir
seems like this ******* needs a lesson tought.
ripped me off nasty
Old Jun 19, 2010 | 10:18 PM
  #36
mannyman84's Avatar
if compression comes out the valve covers then thats definatly the valves not sealing right and your car will run like crap with no power at all.. if the smoke was coming out the tail pipe then it would be the piston rings and you would be burning oil like crazy... maybe when your copression stroke comes around and explosion happens all that heat is escaping through the valves and making the heads get hotter than they are supposed to
Old Jun 20, 2010 | 02:36 AM
  #37
ss.slp.ls1's Avatar
Yeah, you should have, lol. It's already gone now.
But it's not too late to buy an LT1. I see them for sale all the time on CL. Let me know if you want to do a swap sometime.
Old Jun 20, 2010 | 12:15 PM
  #38
ok check it out..
Thats some fucked up ****, like I always say a good, honest mechanic is hard to find, when you find one stick with him.
Old Jun 20, 2010 | 02:45 PM
  #39
LS1Adam84's Avatar
Damn dude that sucks that that guy ripped you off hardcore, really just horrible.
Time to do a 350 build lol.
Old Jun 20, 2010 | 05:40 PM
  #40
carbonfiberbird's Avatar
man thats sucks man hopefully things work out for you. You can tell if you have a 305 or 350(it should say what it 305 or 350) by looking at the casting on the back of the motor just below the passenger side head in the back, tho I think you may need the motor out to see it. If you have to pull it out again at least you can check.
