what should i look for when buying a used rear end w gears?
not very familiar with rear ends.... looking to buy one with 373s to swap in my 98 camaro.. what should i look for as far as wear and tear or any potential problems when looking at a used rear end? any input would be great. dont want to get ripped off
Complete 2002 camaro ss rear end with 373 gears and true track posi unit in it. Price is $450 or best offer...
thats one im looking to buy.. was posted on craigslist... what to look for with this rear end. thanks
First off make sure the seals dont leak, however its always a good idea to replace them while it is out. If you are able to remove the rear cover if it already isn't off and inspect the mesh between the pinion and ring gear. The proper way to inspect the pattern wear is to get spray paint, paint the ring gear and and spin the assembly. The wear marks should show a clean pattern in the middle. Also look for signs of excessive metal shavings in the oil or the magnet. The last thing to check is the bearings but you wont be able to do this without a tear down, but you can atleast check the axle bearings. grab the studs (wear gloves) and try to move it up and down. Make sure the any bolt holes arent stripped and that mounting holes arent oblonged. Good luck!
thanks man.. thats a huge help.... the rear will be off the car when i go see it and i asked to make sure it was opened up. any way to double check that they are 373s and not stock? he also says its a detroit posi unit on the rear
