Clutch Install?
2 questions (I hope you dont mind):
1) If, in the future, I want to upgrade my master, do I have to take the tranny out again?
2) Where can I get this shim at?
Thanks!!
Sid.
just remove the master clyinder line that goes into the slave and replace it with the new piece. and bleed again.(and adjust if you get an adjustable unit.)
as for the second question, i have no idea. summit maybe?
LS7 clutch kit, for $460, comes with the flywheel as stated above, which pretty much eliminate $100 for the need to resurface and rebalance my old flywheel.
So far, the clutch job project will cost close to $650 and that is without labor since I am planning to do this project my self.
You will need a long maybe 3' or more socket extension for one of the bolts.
I had a hard time just unhooking all of the electrical connections as each one released differently. After doing it once I could probably do it in one day now but it was no walk in the park.
Ryph
Ryph
Ryph
But seriously though, 3', i thought i saw 3". I need to look for and buy that extension then.
EDIT: nevermind, I'll just use a 3 6" extension, hell 4 6" if i have too. I am pretty sure I already have at least 3.
. I have a low-profile floor jack, and a little transmission jack that worked perfectly as well if you need to use either. 2 questions (I hope you dont mind):
Thanks!!
Sid.
https://ls1tech.com/forums/manual-tr...r-writeup.html
Thanks! I think I will be needing that, it would save me $10!!
