Western Members CA, AZ, NV, UT, CO, NM, HI
Flp headers???
Old Oct 7, 2010 | 09:32 PM
dreemurY2K SS's Avatar
Question Flp headers???
I have a question.
How good are FLP headers (finish line performance)
and would they work with a 3" pacesetter y pipe for my 99 z28???
or what could I use?
also how much do these headers go for
Old Oct 7, 2010 | 09:42 PM
also were could I get the brackets were the coils bolt up too??
an were could I buy separate MSD coils, i have 6 of them
Old Oct 8, 2010 | 11:43 AM
KCFormula's Avatar
I've had 2 sets of FLPs. New I think they were like $1300 w/ the offroad Y, and high flow cats. The first set I had on my LT1 a looong time ago, and they were the first set of headers I put on my LS1 car. For ground clearance they can't be beat. If you are looking at a used set (assuming you are because they haven't been made in years) look for excessive wear on the coating and make sure the clamps are in good condition. If the clamps are bent/broke you can get them from a Ford dealer as they are the same ones used on Powerjoke diesels.
I have no clue what the high flow cats that come with them do for emissions because I ended up running the off road pipes 99% of the time. The only difference I noticed was at WOT they were more quiet with the cats on.
They won't work with your 3" Pacesetter Ypipe due to the mounting points and flange requirements.
Old Oct 8, 2010 | 12:05 PM
00SSLS1's Avatar
FLP headers were the Kooks and ARH headers of it's day.
Old Oct 8, 2010 | 07:19 PM
well they came with the car, so im not buying them lol
i just need a y pipe that will bolt on these flp lt headers
Old Oct 10, 2010 | 03:34 PM
how much could these sell for??
Old Oct 10, 2010 | 04:34 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i suggest you go to a reputable muffler shop and have a y-pipe made with a good merge collector like a flowmaster Pt# Y300400
Old Oct 10, 2010 | 08:04 PM
KCFormula's Avatar
For reference I don't know if its applicable here but the FLP Y has an actual merge collector, no spike, but its got an actual merge.
Old Oct 11, 2010 | 06:54 PM
what would happen if i shave that lip that it has around the collector??
half of the good exhaust shops charge to much to get a y pipe done or anything, ive asked a couple places an for what they charge i can order some new lt's and y pipe =/
Old Oct 11, 2010 | 07:21 PM
SS MPSTR's Avatar
I had a set of FLP's on my LT1 ages ago, and while they fit really well, it seemed like they forgot you need to run spark plus/wires on an engine. Access was horrible, and I sold mine.
Old Oct 11, 2010 | 07:37 PM
how much could i sell them for, there in good condition an are ceramic coated from what i see an aint rusted or anything
Old Oct 12, 2010 | 01:53 PM
KCFormula's Avatar
Without the matching Ypipe I don't think you can get much for them. The true value to those headers is they had easially removable cats in the Ypipe, without a Ypipe they are only good for an open header/race type situation which most all out race guys want a larger primary headers w/ a spike and merge.
Old Oct 12, 2010 | 09:19 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
didnt know that, thanks for the info
