Western Members CA, AZ, NV, UT, CO, NM, HI
Help...
Old Dec 22, 2010 | 10:35 PM
juniorz28's Avatar
Question Help...
I've been noticing that my car alarm is going ON by itself... Especially after locking the car. I've been driving the car thru rain and I was wondering if something electrical got damaged thru the rain... Any input would be appreciated. THANKS.
Old Dec 22, 2010 | 11:07 PM
lowerthanyou00's Avatar
Start unplugging shock sensors until it stop, check the doors too
Old Dec 22, 2010 | 11:12 PM
Camaropar's Avatar
Umm you do know if you use the power lock feature and close the door the factory alarm arms itself correct?
Old Dec 22, 2010 | 11:19 PM
juniorz28's Avatar
No I didn't know...
Old Dec 22, 2010 | 11:27 PM
juniorz28's Avatar
Weird thing is when I lock the car the alarm goes on.... but when I leave the car unlocked the alarm doesn't even go on
Old Dec 22, 2010 | 11:55 PM
SSkull's Avatar
I had this same problem when I first got my Z28. Alarm would go off after locking it, and I would have to hit lock one more time to shut off the horn.
Ended up grabbing one of the modules that plugs in where the spare tire jack is from a v6 while at the junkyard one day just as a what the hell idea. Fixed the problem.
Maybe something got wet, or the module just plain old went bad. That's how it was with mine.
If you've got another camaro, or a friends, just ask to swap them real quick.
Old Dec 23, 2010 | 12:02 AM
IT_SS's Avatar
i bricked my car once over the daym alarm >
Old Dec 23, 2010 | 12:09 AM
94'BLKBRD's Avatar
Unplug the shock sensor on the passenger side wheel well. Remove the plastic trim and you'll see the sensor.
Old Dec 23, 2010 | 12:15 AM
juniorz28's Avatar
I tried camaropar idea.. it worked. I locked it from the power lock and close the door and it worked.. thanks everybody for they're inputs.
