Western Members CA, AZ, NV, UT, CO, NM, HI
HELP: 99 Camaro wont Start, Misfire, & P0300 code
Old 01-12-2011, 05:16 PM
s/c'd cav's Avatar
have you tried it with out the maf ? if not unplug it with the key off , then try and start it , might take a couple times to get it to pop the maf code and revert to the SD side of the tune
Old 01-12-2011, 05:24 PM
EVERETTDREW's Avatar
I did try it without the maf sensor and it still was shitty. Does anyone know what the best gap is for the ngk tr5's? I gaped mine to .050. They came .040 from the store.
Old 01-12-2011, 06:00 PM
mannyman84's Avatar
Email me your vid.
Manuel_reyes84@yahoo.com I can help u out if u need wiring diagrams and all that stuff, I have info at work.
Old 01-12-2011, 06:05 PM
Originally Posted by mannyman84
Email me your vid.
Thanks a lot video has been sent.
Old 01-13-2011, 08:50 AM
Started taking the plugs that I just installed on Saturday out and there already getting fouled. Smell like gas and have carbon on the end. They were dry. I am going to try some different coilpacks this weekend.
Old 01-13-2011, 09:42 AM
s/c'd cav's Avatar
i havent seen to many LS coils go bad , but anything is possible
to me it sounds like the computer is commanding it to run rich , id look at the MAP , IAT and coolant temp sensor , though it would be more helpful to have a scanner to read them through the computer
Old 01-13-2011, 09:50 AM
What does your car do when the map sensor goes bad?
Old 01-13-2011, 11:06 AM
s/c'd cav's Avatar
it can go rich or lean , drive poorly , or it can give the pcm a false barometric reading
Old 01-13-2011, 11:19 AM
XpEdItIoUs's Avatar
Originally Posted by EVERETTDREW
I also torqued it down 44 and then 89. .
I hope that was in INCH lbs and Not FT. lbs.
Old 01-13-2011, 11:21 AM
XpEdItIoUs's Avatar
Originally Posted by MrElectric03
The engine sensor fuse being blown wont always make it run rough. My parents 01 SS blows the fuse as soon as the ignition is turned on but runs great with no issues.
thats a short to ground on the power side somewhere in the circuit.
Old 01-13-2011, 11:24 AM
XpEdItIoUs's Avatar
If you did torque the intake manifold to FT. lbs instead of inch lbs. you most likely stripped some of the threads on the heads.
Old 01-13-2011, 11:52 AM
  #32
The torque wrench was inch lbs, and I was looking for the ground but was having a hard time finding it.
Old 01-13-2011, 01:39 PM
  #33
ss.slp.ls1's Avatar
I doubt you would successfully make it past the first pass if it was ft.lbs...
Old 01-13-2011, 02:04 PM
  #34
s/c'd cav's Avatar
well i would think it would be 2 or more wires pinched together from the intake , i know i had to be careful with the knock sensor wires on my gto when i swapped to the fast 78
you coulda pinched or cut the map wires also
but trying to figure out a sensor short of pulling it all back apart is where a scanner is helpful , even then pulling it apart doesnt show the whole picture
i know with my old cavalier , they had major issues with the IAT plug , when the factory crimped the wires at the plug , they would break inside and still look good on the outside , sometimes it never set a code other times it came on right away , and being a auto trans it slammed into each gear like it was a full on drag car , and was in 4th gear before crossing the intersection
Old 01-13-2011, 02:16 PM
  #35
When I took the MAP sensor off this last time one of the orange rings at the bottom was coming off, maybe that is an issue.
These are the stock injector sizes below:
1998: 28.6 lb/hr
1999-2000: 26.4 lb/hr
2001-2002: 28.8 lb/hr
The true size of the injector for my car is 22, and for 98,01,02 is 24. Will this make a big differcne and make my car run more rich since it is in my computer to run for 22? Or am I reaching to far on this?
Old 01-13-2011, 02:20 PM
  #36
XpEdItIoUs's Avatar
Yeah the bolts will snap off around 22 ft lbs or so. But i have bought a set of heads that had 2 of those threads stripped before. Just throwing a what if out there since its nearly impossible to diag a car if you can see exactly whats going on with it. Im just bench diag like everyone else, Hes just going to keep throwing parts at the car this way.
Why don't you go look at his car for him? Havn't you diag it before?
Old 01-13-2011, 02:27 PM
  #37
He said he would look at the car for me. I have to get it towed out to Orange county, and right now using my AAA it will cost 250 to tow it. I tried to see if I could upgrade it to the 100 miles but Ive used the AAA since and didnt update it at the time so I have to wait. All else fails I am going to see if I can use my dads card to get it towed. I dont plan on throwing anymore parts at it since the funds for this project are low, but I am just trying to see what I can look out for or what I could do with my current situation. Thanks for your suggestions.
Old 01-13-2011, 02:29 PM
  #38
I have a clip of the car and what is doing but I dont have a photobucket page or anything to host it. Mannyman84 has offered to host the video.
Old 01-13-2011, 04:44 PM
  #39
s/c'd cav's Avatar
most injectors are rated in the 40-45psi range , and has been all over the place with their ratings , i think the older obd1 and early obd 2 were in the mid 30psi range , then moved to mid 40 , then mid 50 and mid 60
so you have to look at the psi they are rated at also , and why you would see 26.4 for the 99-00 and actul of 22
but a couple lb hr larger the computer should be able to make up for
Old 01-19-2011, 01:17 PM
  #40
Well if you get the P0300 misfire code then you might get nervous. Turns out I have a badly bent intake valve, and a bent pushrod on number cylinder #7. Had Chris and Jason check it out in OC. Looks like its time to start getting the parts together. Just wanted to updat this thread since I know other people have this issue. What casued this to happen, im not sure.
Quick Reply: HELP: 99 Camaro wont Start, Misfire, & P0300 code
