Western Members CA, AZ, NV, UT, CO, NM, HI
are bullet mufflers enough to create backpressure?
Old Feb 12, 2011 | 10:57 PM
hitmanws6's Avatar
Put it this way, if backpressure was good there would be no aftermarket exhausts. X pipes will always edge out H pipes slightly powerwise. A Y pipe with a good merge and a cutout will make good power, but duals will have the midrange over a y anyday
Old Feb 12, 2011 | 10:58 PM
180ls1's Avatar
Originally Posted by chevyrunner
how bout x pipe from the ltubes with the cherry bombs?
or x pipe on there with a chambered borla or magna flow mufflers?
i think cherry bombs flow pretty well, they are a straight through muffler much like a bullet if i am not mistaken. I would have an xpipe fabbed up infront of those mufflers. But im not sure the cost is worth the gains. I woild not expect to see more them 5-10 horsepower at the most.
Originally Posted by djsanchez2
Why not just get a dual set-up?
Systems are already made and proven. Ease your worries and handle the power/back pressure issue with a simple bolt-on
this is an ideal setup for our cars
Originally Posted by cntrmnt02ss
do a search for specifics on scavenging, but it basically is when your exhaust system is almost sucking the exhaust gases out of the engine because of differences in pressure. you removed the scavenging from your srt... probably why you noticed a power loss.
correct.
Old Feb 12, 2011 | 11:17 PM
fspeedster's Avatar
The proper exhaust is the one that offers the best blend of back pressure and flow for your specific motor. If you have a mild ls1 you will make more power (specially Torque) with a 3" exhaust then a 4". If the OP's car is bolt on/mild ls1 he might lose a few Hp up top but gain more torque in the lower rpm's. Going from bullet's to a chambered muffler. Hooker makes some good chambered mufflers and sound good too!
Old Feb 12, 2011 | 11:27 PM
180ls1's Avatar
no its not, you dont want backpressure. Backpressure causes a decrease in horsepower PERIOD. Do some research on it, its an old myth.
OP disregard this guys post.
Old Feb 12, 2011 | 11:32 PM
chevyrunner's Avatar
i appreciate all this input guys... in my humble opinion it feels like my exhaust is holding me back... it feels like the car has a delay when the gas is floored. the car is tuned and makes great power but just one of those things i feel.. i maybe wrong. i just threw sum cbombs on there with 2.5 inch true dual piping from the ltubes back.. it was just something i did in a hurry. i feel like theres something better i can do
Old Feb 13, 2011 | 03:08 AM
Mr.z/28's Avatar
I added a cutout to my stock exhaust and man I felt a difference in the way it responded. I wanted True duals badly, so I went straight pipe with chamber 1s and felt as if the car wasnt responding like I wanted it to. so I then added at H crossover pipe with muffler delete and Im very happy right now, but I know that If I want it the right way, Im going to have to get me some LTs, X pipe, and throw in my Dynomax Bullets.
Old Feb 13, 2011 | 03:29 AM
LS1Adam84's Avatar
Di not listen to mr. z28 he is dumb, like literally dumb.
For you I sugest a dual exhaust with any Super awesome upgrade.
Old Feb 13, 2011 | 04:47 AM
fspeedster's Avatar
What system do you think would work for him? A 4" exhaust or a 3"? The 4" will obviously create less back pressure. What mufflers would you recommend?
Old Feb 13, 2011 | 04:55 AM
fspeedster's Avatar
Read up smart guy, you can't just throw on the biggest, highest flowing exhaust, it has to match your engine specs.....http://www.summitracing.com/parts/BOR-40941/
Old Feb 13, 2011 | 05:56 AM
hitmanws6's Avatar
Not really... 4 inch exhausts on stock motors will do no harm. You can't have too free flowing on an LS or LT. OP choose a crossover pipe of your choice and be done with it.
Old Feb 13, 2011 | 07:55 AM
C5natie's Avatar
what is scavenging?
Your exhaust is produed in pulses as cylinders fire. If you have headers this is where collector size and length come into play. As the gases exit the different primaries into the collector it also creates a spiral effect that help creates pull the gases out (this is negated by the use of cats which dont allow for the spiraling effect. X-pipes help by equalizing pulses and pressure in both exhaust banks in a true dual setup.
I just ditched my chambered muflers and have straight 3' pipe from the collectors to 3' bullet mufflers and an x-pipe for almost 0 backpressure. I picked up over 2/10s and over 2mph at the track.
Old Feb 13, 2011 | 07:59 AM
  #32
C5natie's Avatar
Btw, Cerry Bombs are louvered inside which are terrible for flow and suck more than some chambered mufflers. They actually will create backpressure. You want bullet mufflers with a perforated center (little holes) which flow almost as good as straight pipe. Technically any muffler, even bullets, create flow resistance (backpressure) or else they wouldnt muffle, theyd be straight pipe. Lol. The perforated core allows for a minimal amount of gases and sound waves to be caught in the packing material. What matters is at WOT and thats when they flow the best.
Old Feb 13, 2011 | 08:48 AM
  #33
can you post pics of your setup?
Old Feb 13, 2011 | 12:03 PM
  #34
180ls1's Avatar
a 3" x pipe with two bullet mufflers and all manderal bands.
no **** sherlock, thats why i said it has to promote scavenging but not create back pressure. I never said anything about having the biggest exhaust...
this!
good to know about cherry bombs, and agreed to the rest of it.
OP it might be the size of your cam and stall/gears that leaves you feeling like you dont have much down low. Adding an underdrive pulley and removing some weight should help with that.
Old Feb 13, 2011 | 02:29 PM
  #35
LS1Adam84's Avatar
Thank you nate, that was exactly correct. If the pulses are smoothed it allows for the signal to travel faster in the right direction.
Old Feb 13, 2011 | 03:39 PM
  #36
HEYPAL01impala's Avatar
http://kalecoauto.com/index.php?main...&products_id=3. Good to go. Grab some cross drilled brake lines. But in all seriousness nate and most other in here are right.
Old Feb 13, 2011 | 03:46 PM
  #37
http://kalecoauto.com/index.php?main...&products_id=2.
Old Feb 13, 2011 | 04:36 PM
  #38
MrElectric03's Avatar
Originally Posted by HEYPAL01impala
You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is dual input O-Pipe with standard finish.
Now thats ****** hilarious! Good one
Old Feb 13, 2011 | 05:36 PM
  #39
Mr.z/28's Avatar
Get Off My Nuts Adam!
Old Feb 14, 2011 | 12:20 AM
  #40
C5natie's Avatar
Its hard to get under the car but I'll try tomorrow. I did do one thing backwards due to space constraints, I put the bullets (I got the 24" long ones) before the x-pipe. My bullets are right after the header, then extend to a x-pipe, followed by a foot of pipe and then turndowns. The bullets being so close might not allow the exhaust to pulsate as smoothly as straight pipe which means the x-pipe is now more for sound tuning though it still does help with balancing the two banks. I put this setup to fit in a tight tunnel and more importantly to flow max amount of exhaust at WOT so exhaust scavenging at low rpms isnt priority. Even then it way out flows my old setup and I feel more hp/trq all throughtout the powerband...which translated to the track where it counts.
