Western Members CA, AZ, NV, UT, CO, NM, HI
ATTENTION ALL.... help me out
Old Mar 29, 2011 | 04:42 PM
mannyman84's Avatar
Default ATTENTION ALL.... help me out
I have my GF's 2000 Z28 and everytime u floor it, it won't shift unless u let go of the throttle. (keeps hitting the rev limiter) I'm thinking it needs a shift point adjustment. Has anyone ever been through this?
Old Mar 29, 2011 | 04:59 PM
LS1Adam84's Avatar
Yup mine did this on the freeway and it was 3-4 going out then all the sudden it went out. might be the clutches slipping meaning its almost time for a rebuild.
Old Mar 29, 2011 | 05:02 PM
raidernation3017's Avatar
Mine was doing the same thing. After about a week I took a ****.
Old Mar 29, 2011 | 05:03 PM
00SSLS1's Avatar
leave it, least you know she won't be speeding
Jeremy 92 RS's Avatar
x 2. Start savin.
A stock car that hasn't had the tuning messed with wont need any type of adjustments. The auto trannies in our rides are electronically controlled.
Old Mar 29, 2011 | 05:50 PM
IT_SS's Avatar
agree with all above, time for a rebuild, I have a guy off of firestone and central, pm me if interested
Old Mar 29, 2011 | 07:01 PM
98V8gorilla's Avatar
hit up xtreme trans.
Old Mar 29, 2011 | 07:57 PM
Empatho's Avatar
I'm taking my car to CMS for an a4 to m6 swap on April 12, so ill have the spare 4l60e. You can have the transmission for $120, pm me if you are interested.
Old Mar 29, 2011 | 09:30 PM
mannyman84's Avatar
Doesn't really make sence. Tranny isn't slipping at all. Drives and shifts fine. Just at WOT it doesn't shift like it should.
Old Mar 29, 2011 | 09:36 PM
6spdchevy's Avatar
From: Oklahoma City, OK/North Long Beach/Paramount, CA
+1
Old Mar 29, 2011 | 09:49 PM
LS1Adam84's Avatar
Mine was the same way until I got on it at WOT.
Old Mar 29, 2011 | 09:50 PM
00SSLS1's Avatar
Check the tranny fluid when car is fully warmed up and level. It needs to be right on or you will have shifting issues.
Old Mar 29, 2011 | 10:33 PM
nomoneyz's Avatar
My car also did this before the trans was completely toast. I would say rebuild time.
Old Mar 29, 2011 | 11:03 PM
mannyman84's Avatar
I still want to do the tranny oil change and see how it acts. Probably someone put the wrong fluid. :/
Old Mar 29, 2011 | 11:20 PM
black_phoenix's Avatar
damn.... hopefully its just a minor issue, maybe you just need to tweak the tranny a little with a minor tune?
But whatever it is, good luck.
Old Mar 30, 2011 | 12:01 AM
The 4L60E in our cars only calls for Dexron III ATF which is very generic...it's not like they need a synthetic or specialty ATF from the factory. As much as it sucks, I'm sure its not the fluid.
Old Mar 30, 2011 | 12:21 AM
180ls1's Avatar
eehh maybe not. Did you buy the car recently? Sounds like someone may have dumped it before the trans was going to take a poop.
Old Mar 30, 2011 | 12:26 AM
Empatho's Avatar
My old s10 was doing the same thing, and a few days later it gave the ghost.
Old Mar 30, 2011 | 01:15 AM
20TA02's Avatar
This happened to me... that same day it took a ****...
Old Mar 30, 2011 | 01:20 AM
mannyman84's Avatar
This happened long time ago. Maybe like 1 month and half ago, shifts fine unless at WOT.... And there is an update from GM that all auto trans shall take dexron VI... Dexron III only for T56
