Western Members CA, AZ, NV, UT, CO, NM, HI
HelP!!!
Old Oct 27, 2011 | 04:15 PM
griffsbombelco's Avatar
Default HelP!!!
This car is driving me nuts. Car will not stay running fires then dies vats was removed by cms also barro map tune installed I was able to get it to run for awhile feathering the throttle. Car has good feul pressure and computer has constant power. I'm lost car sounds great with initial fire then something changes
Old Oct 27, 2011 | 04:18 PM
mannyman84's Avatar
If u hold the gas will it stay on?
Old Oct 27, 2011 | 04:31 PM
RPD_Vette84's Avatar
More info on the setup please.
Old Oct 27, 2011 | 04:49 PM
70 camaro
Lq4 with th400 trans
60lb injectors
Barro map
Sd tune from cms
Car sound good on first fire then shuts down I was able to het it to run barley once has cOnstant fuel pressure and ecu has power
Old Oct 27, 2011 | 05:02 PM
I was thinking vac leak but I thought it should still run right
Old Oct 27, 2011 | 06:02 PM
Depending on how big the vacuum leak is it could cause an issue. How long does it run before it dies?
Old Oct 27, 2011 | 06:27 PM
Just a second or two I originally thought vats but tuner insured me it was turned off I did reuse throttle and intake gaskets
Old Oct 27, 2011 | 07:17 PM
ive reused them with no issues. sounds like vats but you said hes sure its tuned out. hows all the power connections and are all sensors plugged in?
