tucson or phx i need help with swapping my motor
im located in southeast tucson and i need help with what extra parts i may need for swapping my ls1 for an lq9 i have a procharger as well, and if you done this kind of swap before i need some guidance on what to do so please call me or text me at 5208917632 and or pm your numbers and i will give you a call when i get a chance. you help will be very appreciated thanks.
I'm in Phoenix. Havn't done an LQ9 swap, but I have done an LS7 swap.
For parts you should have most of what is required as the front AC accesories swap right over. You should get a new K-member while you are swapping, trust me on this, it makes you life much easier the next time you need to get under the car. Especially if you are incorporating a procharger.
If you are swapping a 3rd gen engine for a 4th gen you will need a few wire harness adapters that are available online. You will need a cam sensor relocation harness (or extend your own). You will need to consider the intake manifold you are using. If you are using a gen 4 intake, you will need an adapter harness as well.
Give me a PM if you need any other advice.
