EFI Connections 24x LT1 Coil Conversion Tuner in AZ
I will be converting my 96 Z28 to the LS1 PCM and Coils, using the 24x conversion.
Has anyone in Arizona done this conversion and worked with a tuner to get the PCM dialed in? If possible, I would like to work with someone who is comfortable with this type of setup, so that I can get a base tune to breakin the car and make sure everything is functional. After that, I am looking for a full dyno tune.
Thanks,
Jahajazz
Thanks,
Jahajazz
We did the setup a couple years ago, and I will be doing another soon. We used NicD to get the car tuned. As far as I know... we might have been the first in the area to pull the trigger on the conversion. I am not sure if/how many Nic might have tuned since then. You can email him at nicdtuning@gmail.com though for questions and setting up appointments. I will be going to him again for mine... hopefully soon.
LS1TECH Sponsor
Thanks,
Jahajazz
Thanks,
Jahajazz
