Pulling engine from the bottom next weekend
I do see how it is less connectors, I am only saying that there is no one right way, fastest, yes, but best would be the way that each person finds works for them, in the car world everyone has an opinion and opinions are like ********, everyone has one and they all stink.
I found that just quickly undoing the grounds and what have you worked for me, but then again I don't need to pull the engine every two weeks because I did something incorrectly.
if you wanna talk about pulling something that needs to be redone, lets post pics of that rats nest of a harness on the purple car. who did the swap? ill give you three guesses but youll only need one
Let's get this back on track this is for Dave and pulling his engine from the bottom, Keliente's how to is pretty spot on, it looks like you have what you need Dave.
If Gil/Christian wish to further discuss anything else you know how to reach me.
I'm so pissed. I just got an email from Harbor Freight.
They shipped the dollies and everything from Camarillo yesterday, except the lift.
That was shipped from SC, and expected to arrive on 7/10/13.
It looks like I have to drive to HF in Pasadena and pick one up then return the one that gets shipped to me. I was trying to avoid that in the first place.
So, with my odometer at 152K+, what are the thoughts on changing cam, rod or main bearings?
I did get new LS7 lifters and LS2 timing chain.
Debating on getting a new oil pump or not.
There's a Melling M295 in Glendale for $69.
I was thinking of just shimming the stock spring.
I've ported several OEM pumps. Heck I think I even have one or two of them in my garage.
As far as changing the cam, if the lobes look good with no pits it should be ok, no scoring or excessive wear either.
If you are planning on going to a larger cam, then that would be a good time to do so.
I always leave the wheels bolted up.
remove driveshaft & shifter, wiring, and hoses (brake, coolant, vacuum, etc). unbolt trans crossmember and lay trans on dolly. unbolt top of struts, unbolt k-member, start jacking car up, making sure nothing is being pulled. once car is high enough, roll it out!
