Western Members CA, AZ, NV, UT, CO, NM, HI
install help, modesto area, asap
Old Nov 21, 2015 | 02:01 PM
Killer_Z's Avatar
Default install help, modesto area, asap
Hey guys need help with install today please. My pcv valve busted and as I was removing the old one I broke the cylinoid under the cowl. So decided to do the air delete. So need someone to do that as well as install plugs and wires. I have work tomorrow morning and its my only car. Will pay. I'm in Patterson. Pm me please for details.
Thanks eddie
Old Nov 21, 2015 | 03:11 PM
Killer_Z's Avatar
anyone ? will pay. cant afford much but can do a bit.
Old Nov 21, 2015 | 04:34 PM
Killer_Z's Avatar
already called in for work today, can't miss 2. please. all i need to do is install the pvc valve / hose, plugs and wires. i can do the air block of plates thats no problem. i can pay 150 cash in hand right now guys
Old Nov 21, 2015 | 05:03 PM
GARAGE_BUILT_Z28's Avatar
The best thing to do is search a how to video on YouTube and do it yourself it's the fastest way you're going to get anything done
Old Nov 21, 2015 | 05:06 PM
Killer_Z's Avatar
yeah i know. i just can't get to the back bolt along the firewall to remove the bracket thats ontop of the pcv hose on driver valve cover. passenger side plugs i know if i take my time i can do it. i know easiest way is to remove coil packs.
Old Nov 21, 2015 | 05:13 PM
That hard line pvc that runs to the back driver side from the passenger side should be just inside a plastic clip if I'm not mistaken
Old Nov 21, 2015 | 05:23 PM
Killer_Z's Avatar
yeah for the air pump it was a clip. but theres like a metal bracket there too. actually covers up a spot on the coil packs. and cant remove driver side coil pack because that bracket is there. and a bolt is behind there good. might have to get a ride to oreilly to get a set of ratcheting wrenches. i believe its a 15 from researching.
Old Nov 21, 2015 | 05:33 PM
Ahh I see its been awhile since I've seen under a good with egr and air installed but with the right tools and some time you can do it these cars are very easy to work on
Old Nov 21, 2015 | 05:52 PM
Killer_Z's Avatar
yeah right tools are key word.
