Western Members CA, AZ, NV, UT, CO, NM, HI
Need help in AZ !
Old Jun 8, 2023 | 05:23 PM
slothman's Avatar
Default Need help in AZ !
Guys, I might need some help rebuilding my 10 bolt, I am located in AZ / PHX area. I am looking into it, but sounds like the rear end is toast. I currently don't have $3-4 grand for a 9 inch etc. Car is stock and I don't plan on beating it up. Is there anybody in the area that could help, or know a guy ? I really don't want to pay a shop $1500 just for a 10 bolt rebuild. Thanks for any help !!
Old Jun 8, 2023 | 06:33 PM
gjohnsonws6's Avatar
Go find a used one, check AZLSX and AZFBA on Facebook.
Old Jun 8, 2023 | 07:02 PM
slothman's Avatar
I may go that route, but I would feel better with new parts, and new 4.10s. do you happen to know any backyard mechanic type guys ? I am pretty mechanical, however I have never worked on a rear end.
you ever hit any west valley car meets? would be nice to meet some F body guys. Once my car is ok to drive hahaha.
Old Jun 8, 2023 | 07:34 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Info on your car ? Year ? stick or auto ? 3 channel ABS or 4 channel ABS & TC ?
Old Jun 8, 2023 | 07:48 PM
slothman's Avatar
02 M6. it has TC. so I'm guessing 4 channel.
Old Jun 8, 2023 | 08:11 PM
B4CMaro's Avatar
Try phoenix rack and axle maybe
M6s' are not easy on rear ends. Since you have a 4 channel ABS & TC, a replacement rear end also has to be of 4 channel. Brake plumbing and the electronics are not compatable between the two styles.Putting a 3 channel rear into your car will cause the ABS dashboard light to be forever on and can't be fixed/changed in the computer as it's a safety function. And only get one from a 98-02 car, camaro or firebird.
Also Aftermarket rear ends have much difficulty in the 4 channel realm, some don't even offer it, some that have it mostly don't work.
Old Jun 8, 2023 | 08:32 PM
slothman's Avatar
I definitely don't want a **** load of lights on the dashboard after a new rear end lol
 Michael S. Palmer
Old Jun 8, 2023 | 08:33 PM
slothman's Avatar
thanks, I'll check it out.
Old Jun 8, 2023 | 10:27 PM
It’s really not worth it to put money into a 10 bolt. You are better off finding a temp replacement until you’re ready for an aftermarket rear and especially so being a manual. I used to do most all of the different shows and “gatherings” years ago all over the valley and state but stopped everything when I parked my TA in 2012. It’s almost ready to run but I probably won’t attend many shows. I’d rather do short trips canyon carving.
The only things I don’t do are transmissions and diffs. I have a few people I can talk to about side work and I’ll get back to you on that. In the meantime I highly recommend finding a decent used rear. Join the groups and make a post, you’ll find one in no time.
Old Jun 8, 2023 | 11:26 PM
slothman's Avatar
Thumbs up
I appreciate any leads you could dig up.
Old Jun 9, 2023 | 12:12 PM
Since you have an M6, the code for that is GU6 (3.42s'), The automatics got GU2 (2.73s') and GU5 (3.23s').
Old Jun 9, 2023 | 07:23 PM
slothman's Avatar
my plan is to go 373s or 410s. car isn't going to be tracked. just a weekend car. I think the 10 bolt will be fine, car doesn't have much power.
