Highest compression on 91 pump gas
You need to consider what kind of cam overlap you are running to determine dynamic compression ratio.
I'm looking at running a Comp Cams 226/222 .585/.563 114 LSA on my 402 stroker (4" stroke). I don't know squat about DCR, so any help you could give would be appreciated. (I did run a search just barely and came up with some informative looking threads; but honestly don't have the time right now to read them all to "understand" what's what). A "simplified" summary would be helpful.
Right now, I'm trying to decide if I want to stay NA and max out the compression, or add the STS Turbo and keep compression a bit lower. Gas mileage is unfortunately a big factor, as this is first and foremost a daily driver.
Staying CA legal is also a goal since the move to San Diego is only 3 months away now.
One bonus of the turbo is eliminating the need to swap headers off and on.
bore: 4.00
stroke: 4.00
chamber volume:
head gasket thickness:
gasket bore:
deck height:
piston dish or dome volume:
rod length:
.006 duration (adversised duration)
LSA
ICL
