Western Members CA, AZ, NV, UT, CO, NM, HI
Pacesetter Headers installed
Old Nov 16, 2006 | 03:27 PM
camarosslover21's Avatar
Default Pacesetter Headers
Does anybody know of anybody in sac that will put on LT pacesetter headers on a camaro ss for cheap?? Everybody I asked said they were hard to put on and it would cost a lot.
Old Nov 16, 2006 | 03:33 PM
NviouSS's Avatar
they're not hard to do. can be done in 5-6 hrs. why not try to do them yourself?
Old Nov 16, 2006 | 05:08 PM
Azrael's Avatar
They are not hard to do, actually the hardest thing is disassembling the stock exhaust... hahah.
If you need help drop a line!
Old Nov 16, 2006 | 06:10 PM
radz282003's Avatar
You may consider trying Force Fed Performance
Old Nov 16, 2006 | 10:04 PM
2001bluerata's Avatar
I did it myself w/ the help of some 2x4s in about 3 hrs!
Old Nov 16, 2006 | 11:27 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Try posting this in your Regional Forum.
Old Nov 17, 2006 | 12:46 AM
Long Beach's Avatar
Like was said before the manifolds are the hard part. Most of those bolts are rusted and a pain in the *** to get loose. Just get your self some basic tools with extentions and get a jack and jack stands and you should be able to do it yourself. Good luck
Old Nov 17, 2006 | 03:14 AM
BayAreaSS's Avatar
Thats what i heard. I will be attempting this in the future
Old Nov 17, 2006 | 12:58 PM
armkneez8's Avatar
Get some WD-40 for the exhaust manifolds and it's easy.
Old Nov 17, 2006 | 01:53 PM
Revelation Z28's Avatar
well depending on how long its been since the bolts came off on the Y pipe, they are bound to snap off from rust and heat cycles.
just like the head bolts/studs. the heat cycles "glue" them to the threads.
get some PB blaster, seafoam deep creep aerosol spray, and it thoes dont work try penetrating oil concentrate.
