Black smoke! Need help Bay area
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
Originally Posted by CaliboyTA
did u had the oil consumption problems before the cam swap or RIGHT AFTER the cam. You should do a manifold vacuum test and a compression test to see how well the engine is
When I bough the car it had the cam in it.
I did a compression test when I tuned it about a year ago;
Rick said it was Good,I was going to replace
The manifold gaskets and change the sparkplugs
And maybe cut the CATS off or change the O2s
Any suggestion
Thanks
