Western Members CA, AZ, NV, UT, CO, NM, HI
It hit 113 degrees in AZ got a question ?
Old Jun 21, 2007 | 10:33 PM
Kiss My SS's Avatar
Default It hit 113 degrees in AZ got a question ?
I hear like a rattling sound when i accelerate on happens during the hot summer months here in az this common ? Should i look into this deeper in the winter months nothing at all little help fellas !
Old Jun 21, 2007 | 10:51 PM
GTOSE's Avatar
Now you have my attention
Sparknocking? maybe?
Old Jun 22, 2007 | 12:04 AM
myfast70's Avatar
It sounds like it's knocking! Be sure to run good gas. If you can afford it, it would never hurt to run a couple gallons of race gas with your fill ups. Where in town do you live?
Old Jun 22, 2007 | 12:08 AM
Kiss My SS's Avatar
im in Peoria, i run 91 all the time nothing less. Maybe its time to replace the spark plugs and the wire huh ?
Old Jun 22, 2007 | 10:52 AM
EkS's Avatar
EkS
The rattle you are hearing is detonation (most likely). Is you car tuned? Might want to retard the timing a little for those really hot days or run higher octane gas.
Old Jun 22, 2007 | 11:11 AM
NicD's Avatar
7 Second Club
Pull your MAF and clean it first with some electronic component cleaner or MAF cleaner from autozone or something that doesnt' leave a residue behind. A lot of pinging problems are caused by a dirty maf.
Old Jun 23, 2007 | 12:22 PM
Kiss My SS's Avatar
Ok Thanks Ill Check Those Out.
Old Jun 23, 2007 | 01:02 PM
azceta's Avatar
run octane booster if you cant run some race gas
Old Jun 25, 2007 | 01:29 AM
Soul TKR's Avatar
i'm in surprise and my car is doing the same thing... course, i gotta clogged cat and 114k on the odometer so...
Old Jul 8, 2007 | 09:44 PM
Kiss My SS's Avatar
i thought it might be the spark does it only when its hot out im going to try some octane booster on top of the 91 octane see if it helps if not ive planned on changing the plugs to the msd's and ngk tr 55's good ?
Old Jul 19, 2007 | 03:25 AM
pmoffatt's Avatar
The CPU would have thrown a code about the MAF before it got that bad to cause detonation.
Old Jul 19, 2007 | 07:31 AM
Ruckus46Gt's Avatar
not true at all
Old Jul 19, 2007 | 10:46 AM
NicD's Avatar
7 Second Club
You have no idea what you are talking about as usual. There is a table in the computer that specifies how off a MAF sensor can be compared to the VE table before it throws a code. In an f-body, it's a huge difference. A MAF not only controls fuel but also directly affects load, which timing is based on in an LS1 computer. Why don't you learn a few things before talking about stuff. In addition I would stop while you are behind, you have no idea what you are about to start by trying to follow me around and discredit me on the internet just because I refused to tune your car. You are the kind of customer nobody wants.
Old Jul 19, 2007 | 09:13 PM
White Fire'99's Avatar
cleaning the MAF should be a regular maintenance item, just like changing your oil and putting air in your tires IMHO. it really does make that big of difference if left unchecked. especially if you run an oil based filter.
Old Jul 22, 2007 | 02:25 PM
Braunbeck's Avatar
I agree, never had a MAF based car before, so I read this thread went to Checker Auto Parts, then went home took the MAF off and I couldn't believe how much stuff had accumilated on the wires. Took maybe 10 minutes max to do. I will do this every oil change from now on.
On a side not, I read that this could cause the car to run lean if left uncheck/dirty. Did a plug change and there was signs of detonation and lean signs on a few of the rear plugs. Hopefully this will fix that issue. BTW, found out my arms a to big to change the passenger side plugs, so I employeed the assistance of a friend to help.
Old Jul 22, 2007 | 04:41 PM
six_string_wiz's Avatar
You and every Fbody owner over 160lbs!Seriously,that sh#t is a PITA
Old Jul 22, 2007 | 10:53 PM
Braunbeck's Avatar
**** I'm two of that I go about 320-325 and my forarms are atleast 16-16.5 inches around, so there was no way. I even got under the car to reach up and it was a loosing battle also.
Old Jul 22, 2007 | 11:09 PM
LSGunZ28's Avatar
thats nothing it was 127 in Havasu July 4 weekend..
My friend is having a problem with his car running really hot ( above where it usually reads) these summer days. instead of 210 he is saying its appears a good 30 degrees hotter ( coolant temp) what can this be from
sorry to hijack.
Old Jul 23, 2007 | 06:47 AM
theslow00's Avatar
you are Detonating boss you prob need to pull like 2 deg of timing in the summer
