Western Members CA, AZ, NV, UT, CO, NM, HI
Need some help
Old Aug 21, 2007 | 11:52 AM
Nine7T/A's Avatar
Default Need some help
Hey guys i need help installing my under drive pulley back on my car. My brother pulled it off and didn't mark how it went back on, I put it back on but i get vibrations when my RPMs get to around 3000 and higher, i dont know if its caused by the pulley not installed right. Any ideas?
Old Aug 21, 2007 | 12:02 PM
XpEdItIoUs's Avatar
What did you torque it to?
Old Aug 21, 2007 | 12:21 PM
Nine7T/A's Avatar
65 ft lbs
Old Aug 21, 2007 | 04:32 PM
Nine7T/A's Avatar
Anybody have any ideas? please
Old Aug 21, 2007 | 04:45 PM
Nine Finger 02 Z28's Avatar
How did you get it on to where the crank bolt would start???
Old Aug 21, 2007 | 04:54 PM
Nine7T/A's Avatar
I cleaned around the area where the pulley was going to mount on the crank. then I just pushed it into place making sure it was lined up with the holes for my bolts.
Old Aug 21, 2007 | 04:59 PM
Sorry I didn't noticed that this was on an LT They are a bit diffirent than a LS...Only thing that I could think of is (may be a pain in the ***) but put the stock 1 back on and see if the vibration goes away...
Old Aug 21, 2007 | 05:40 PM
Nine7T/A's Avatar
ok i will try that when i get home. thank you
Old Aug 22, 2007 | 11:02 AM
Nine7T/A's Avatar
Well i put the stock pulley back on and still has the vibration. I belive its coming from my trany. A couple of days ago i broke my third rear trany mount this year. So this time i bought the Energy Suspension rear trany mount instead of the cheap Auto Zone i was buying. Could this be normal
vibrations from using a firmer rear trany mount? Thanks
Old Aug 22, 2007 | 11:24 AM
XpEdItIoUs's Avatar
your getting drivetrain vibration? I have had energy suspension trans mount cause vibrations on my car before.
Old Aug 22, 2007 | 12:37 PM
Nine7T/A's Avatar
Yeah thats where i think its coming from. I guess i just have to live with it unless i can find something better that will not cause any vibrations. Any ideas?
