LS1 Tuner/PCM Tech. Wanted!
My OBD code scanner is displaying codes P0410 and P0418. Can you suggest how to repair this system and/or suggest a PCM technician in Los Angeles?
Much appreciation,
Jeff
310-587-0722
EXI
Much appreciation,
Jeff
310-587-0722
EXI
****, you won't need a tuner or PCM tech to tell you what you already know. I think you'd want a mechanic.
Personally, I'd take a wild guess and check a fuse. Those codes are related to the Air Injection system. Did you mess with anything lately? If you tell us you removed it and now you're getting these codes we will slap you through the net.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
P0418 Secondary Air Injection System Relay A Circuit
P0410 Secondary Air Injection System
Or....are you asking for a tuner to remove this (AIR) permanently from the PCM?
Location: The dirty taint of the country. ...Los Angeles
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
might be your a.i.r. check valves burnt out. If it is thery're real cheap from autozone or you can just get those deleted. Off your manifolds they're two black tubes, one on each side. Follow those and where they "bubble" up is where they are. Hope that makes some sense.
