Western Members CA, AZ, NV, UT, CO, NM, HI
My jackass move
Old Jan 9, 2008 | 07:58 PM
wtomlinson's Avatar
Default My jackass move
So i decided to take the t-tops off today cuz it was somewhat nice out here, and go for a cruise. Well i noticed i had some stuff flapping around in the back (like plastic and stuff) so i pulled over to move it around to the front. guess i set my keys down between the seal and the frame where the hatch closes down, forgot about them, and proceeded to close my trunk on my keys. Thankfully i had my little toolbox with me, i had to crawl over my door, fold the seat down, and stretch back there over my tops, pull the liner back from the trunk release, and actually remove the trunk release mechanism (those 3 bolts) so i could lift it up high enough to get my keys. all of this, while i'm trying not to hit my car too hard to set off the alarm. anyone else make this stupid mistake ever?
Old Jan 9, 2008 | 08:01 PM
ReFtheMC's Avatar
In all seriousness, i got abut half way and got confused. I tried reading again, and i got completely lost, haha...
Throw some paragraphs in there
Old Jan 9, 2008 | 08:02 PM
ae13291's Avatar
i always have a spare key in my wallet! plus coudent u hav used ur trunk release butten??
wtomlinson's Avatar
once i start typing, it's hard to stop and actually read what i put.
Old Jan 9, 2008 | 08:03 PM
wtomlinson's Avatar
yeah but when i closed the trunk, the alarm automatically reset itself, and the trunk release button wouldn't work. i was stopped to eat, and came out and opened the hatch instead of unlocking the car.
Old Jan 9, 2008 | 09:26 PM
WS6_Suicide_Machine's Avatar
reminder, steal your wallet. lol jk
Old Jan 9, 2008 | 10:39 PM
wtomlinson's Avatar
can you get new keys with the resistor anywhere or does that have to be a gm only thing?
Old Jan 9, 2008 | 10:49 PM
SS#2906's Avatar
Not exactly, you can buy the ones from ebay and take it to the dealer to set the correct resistor ohm. They are usually cheaper on ebay than the dealer.
But if you want a spare just in case this happens again, you can go to any key shop. Most of them carry the blanks with the GM logo.
Old Jan 9, 2008 | 10:51 PM
wtomlinson's Avatar
are you talking about going to any key shop for the accessory key? that's what i needed today, but an extra ignition key would be nice.
Old Jan 9, 2008 | 10:59 PM
SS#2906's Avatar
Yeah, most key shops carry the accesory key with the GM logo. As far as the Ignition, you can buy it on ebay and have the dealer program it. Unless you're like me and can't wait for the mail, buy it directly from the dealer.
Old Jan 9, 2008 | 11:26 PM
wtomlinson's Avatar
what's the average price from a dealer?
Old Jan 9, 2008 | 11:41 PM
SS#2906's Avatar
I could be wrong by a few bucks, but around 35-45 dollars.
Old Jan 11, 2008 | 02:55 AM
BigDaddyBry's Avatar
Use a multimeter on your keys, read the resistance, then buy them off ebay. Take them to get cut, and you're set. I believe my blanks cost $6 each off ebay.
Old Jan 11, 2008 | 03:02 AM
Resistance Value Chart for GM VATs (Lists possible resistance values, including acceptable ranges)
• 402 ohms (acceptable range 386-438)
• 523 ohms (acceptable range 502-564)
• 681 ohms (acceptable range 650-728)
• 887 ohms (acceptable range 850-942)
• 1130 ohms (acceptable range 1085-1195)
• 1470 ohms (acceptable range 1411-1549)
• 1870 ohms (acceptable range 1795-1965)
• 2370 ohms (acceptable range 2275-2485)
• 3010 ohms (acceptable range 2890-3150)
• 3740 ohms (acceptable range 3590-3910)
• 4750 ohms (acceptable range 4560-4960)
• 6040 ohms (acceptable range 5798-6302)
• 7500 ohms (acceptable range 7200-7820)
• 9530 ohms (acceptable range 9149-9931)
• 11800 ohms (acceptable range 11328-12292)
Old Jan 11, 2008 | 06:12 PM
wtomlinson's Avatar
is there any possible way to just overall bypass that whole system or is it programmed in?
Old Jan 11, 2008 | 06:14 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
.......Whatta Fool............................................
Old Jan 11, 2008 | 06:34 PM
ae13291's Avatar
lol only my door key!! but then if u get my key u will get full access to my bottle of hand sanitizer in the car, and i think i have like a nice *** knife in the center too smith & wesson
Old Jan 12, 2008 | 12:15 AM
m6ttop's Avatar
I almost did that to a 95 I've been workin on. Pulled some parts out of the hatch,set the keys right next to the latch and almost closed it. Woulda sucked w/ no battery
Old Jan 12, 2008 | 12:52 AM
jermzz's Avatar
there is a bypass. Gotta cut the loom under the dash and solder in a resistor with the right resistance. then you can just use any old key with the right cut.
That or cut the loom and just keep trying to start the car. I believe after 50 tries it goes into bypass mode. Thats how i did mine. I never used a resistor. The security light stays on though.
Old Jan 12, 2008 | 12:19 PM
wtomlinson's Avatar
which specific wire do you have to put the resistor on?
