Western Members CA, AZ, NV, UT, CO, NM, HI
Intermittent Starting Problem...STILL!
Old Feb 19, 2008 | 11:13 AM
NatlCtySS's Avatar
Exclamation Intermittent Starting Problem...STILL!
A few months ago, I posted a thread describing my intermittent startinhg problem with my 1999 Camaro SS. It would turn over, but not start. Once in every 30 tries, it would lite-up like there was no problem, and drive like a dream. when I would get it back home, and turn it off,.....same thing again. Several recomendations where given. I replaced the crank position sensor....same thing. I replaced the cam position sensor...........still the same thing.
Now I don't know what to do.....I tried a new battery. I'm getting 55 psi of fuel pressure at the rails. The pump primes. The fuses seem to be functioning. It just seems that there is no spark when I crank it over, AND THEN SOMETIMES IT JUST WORKS!!!! HELP!!!!!
Old Feb 19, 2008 | 12:05 PM
tails8's Avatar
I'd put money on the IGN relay. When I had my TA it would do the same thing. Swapped out the relay it was fixed..
Tails
Old Feb 19, 2008 | 01:38 PM
theslow00's Avatar
check your ground wires.
Old Feb 19, 2008 | 02:40 PM
1320 killer's Avatar
i had the same problems and i thought it had something to do with the fuel pump. I checked before i replaced it and there was low voltage to the fuel pump and the problem was a bad wire.
Old Feb 19, 2008 | 06:06 PM
NatlCtySS's Avatar
Swapped out the ignition relay. Seems to be working. I guessed I overlooked it before. Thanks for the info. Let's see if it keeps working...............
Old Feb 20, 2008 | 11:53 AM
tails8's Avatar
Cool. About every two years I'd have to replace mine. Dunno why, didn't really bother me..
Tails
Old Feb 20, 2008 | 01:06 PM
lt1 hawk's Avatar
Had a similar problem on my 95 Z28... check your wires and plugs boss.
Old Feb 24, 2008 | 08:17 PM
NatlCtySS's Avatar
The ignition relay did the trick. Been starting up fine for a week now. Thanks for the info. guys.
Old Feb 27, 2008 | 05:48 PM
camarokid323's Avatar
yea i cant get my car started also, how do i go about changing the ignition relay
