Help!!!what gets tread marks off pavement
HAHAHAHAHAHA thats hella funny he should of did some Figure 8s while he was at it if he was gona get busted for it........Try some mustard and mayo JK Degreaser works perfect.... good luck ........BB
IF i get fired
#33
Home depo sells some stuff called "Goof Off" There are two kinds get the one with the yellow container (metal), the other is in a orange (plasitc) container and will not work for you. But i use this stuff at work to take paint out of concrete and use a good ammount on the tire marks and let it sit for a min or two and wire brush the hell out of it. This should be the best stuff, or you can use a pressure washer too..
#34
ive tried everything. Goof Off works when you scrub it (THE KIND IN THE METAL CAN NOT THE ENVIRONMENTALIST HIPPY CITRUS CRAP IN THE PLASTIC ONE).
Aircraft stripper, wipe it on and let it sit. (autozone)
. acid DOESNT work.. rubber is immune to it.
pressure washer works GREAT
ive had success with gasoline and a wire brush
degreaser works ok, driveway cleaner works too. lotsa scrubbing if you have no pressure washer. DON'T get it wet before you put the cleaning product on it, or it wont work worth crap..
#36
seriously i would not **** with chemicals cuz i think theyll cause more trouble...i would try concrete cleaner since its made for oil stains and stuff might work good.....and of go to home depot and rent a power washer........
OOOO i just thought of something!! if your town has ha graffiti hot line call them up see if the'll do it...lol dont say it was u tho
