Anyone with a truck help me out? I needto move a Rearend from Costa Mesa to Paramount
i would have some help getting it in, just incase you dont have to drag it across your carpet, and run the risk of nicking the paint,
and yeah i would say somehwhere around 100lbs. i can carry one around but lifting it in the back of my car would be a risky thing i wouldnt risk.
good luck
good luck
if its a 3ch and you need 4ch your in luck, just grind the outter flanges and re use your axles, if its a 4ch and you need 3ch your screwed lol.
but my blown up rear end is in san luis, just need new gears, its both a 3 ch and 4ch, if that makes sense, it can be both with no modification, ive already done it. im sure if your willing to make the drive my buddy will load it up for you, its got a bad *** dif cover too, this of course is if the 1 down here is 4ch and you need a 3, let me know
good luck
good luck
I was Guesstimating around 3 hours give or take....
Im not next to the rear end now.Ill check it when I get home.Ill grab a pic when i get home along with any casting numbers if that helps too. And of course I will help you guys get it in the truck.
That build thread is old btw. I really need to update that thing. Maybe today.
oh and your gonna need a c clamp to get the 4ch axles out, clamp the axle to the back of the brakes as tightly as possible and try getting the c clip out. and vise versa to put it in, the toner ring makes pulling the axles a little more tricky then the 3ch. dont be afraid to use force to push the axle in far enough to get the clip
#33
no need for all that. it will fit across the back seats..
