F.A.S.T. dual A/F sensor kit
STOP GUESSING AND START TUNING FOR MORE HORSEPOWER!!!
KEEP TRACK OF GASOLINE FUEL RATIOS WITH FAST™
No matter if you are running carburetion or EFI, correct air to fuel ratio tuning is essential to achieving maximum performance. With the FAST™ Digital Air/Fuel Meters, the information needed to make this critical tuning adjustment is available with more accuracy than ever before.
MONITOR A/F RATIOS WITH EITHER 1 OR 2 SENSORS
The easy to use FAST™ Dual Sensor Air/Fuel Meter delivers the complete story about your engine’s tuning. You can read the two wide-band O2 sensors individually or average them together for super accurate readings of your engine’s true air/fuel ratio.
MORE FEATURES THAN COMPETING METERS
In addition to it's industry leading dual sensor monitoring capability, The FAST™ Dual Sensor Air/Fuel Meter has several advanced features. It's built-in data logging capability plays back logged information on the lighted, full graphical display screen, without requiring downloading to a computer. Additional features include outputs for external data loggers and gauges, and a narrow-band simulator function that allows you to feed your engine’s computer a factory signal while using the wide-band sensor for air/fuel measurement and adjustments.
380$ shipped. everything is still in the package unopened & unused.
