Western Members CA, AZ, NV, UT, CO, NM, HI
Tricks for CA smog test?
Old Aug 4, 2008 | 05:26 PM
30th droptop's Avatar
Default Tricks for CA smog test?
Hi,
It's time for that dreaded biennial event - the California smog test! I "should" be legal, and I'm hoping I'll pass legally, but I've got a bit of a cam in the car and my cats have 100K miles on. My last test was a bit of a squeaker.
So I'm wondering if you guys have any tricks. I've heard before that putting some alcohol in with the gas can help. Don't know if that's true or not. Any other thoughts?
Old Aug 4, 2008 | 05:31 PM
94'BLKBRD's Avatar
One trick I know of is to leave a couple of $50 bills on your seat
Old Aug 4, 2008 | 05:41 PM
ConElite's Avatar
At least 2 or three.
Old Aug 4, 2008 | 05:43 PM
94'BLKBRD's Avatar
Yeah two or three should do the trick.
Old Aug 4, 2008 | 05:50 PM
ae13291's Avatar
ethonal gas in the tank
Old Aug 4, 2008 | 05:52 PM
94'BLKBRD's Avatar
I thought it went in the muffler
Old Aug 4, 2008 | 05:55 PM
ae13291's Avatar
damm ur smart man, so that means u fill up gas from ur tail pipe? and then u stick food up ur ***??
Old Aug 4, 2008 | 05:57 PM
94'BLKBRD's Avatar
Nice comeback Ara........nice
 Michael S. Palmer
Old Aug 4, 2008 | 06:52 PM
camarojunky74's Avatar
lol, oh **** was this where the fuel went????
lmao... just when you thought you have heard all the stupid advice you can get, someone recommends fuel in the fuel tank
Old Aug 4, 2008 | 07:02 PM
on a serious note, go to a good tuner or the tuner you have currently have them check your a/f and make sure all is good get the car good and hot and then take it down and cross your fingers
Old Aug 4, 2008 | 07:26 PM
ae13291's Avatar
ethonal gas burns really clean, so if u use about half of that in the gas tank it is sometimes possible to pass even with out cats.
Old Aug 4, 2008 | 07:30 PM
180ls1's Avatar
x2 ethanol does burn very clean and is a very inexpensive way to make sure your car will pass.
Old Aug 4, 2008 | 08:20 PM
djsanchez2's Avatar
So what run E-50? LoL.
Isn't E-85 15% Ethenol and 85% Gas?
Old Aug 4, 2008 | 08:28 PM
180ls1's Avatar
lol at the e-50 but i will have to ask my buddy what he uses on his old jeep whenever i see him again.
Old Aug 4, 2008 | 08:33 PM
ae13291's Avatar
for temporary till he passes smog. its not so hard to believe.
Old Aug 4, 2008 | 10:18 PM
blackls1maro's Avatar
a can of seafoam might help.
Old Aug 4, 2008 | 10:52 PM
letsrun97z's Avatar
i was told by the smog tech to fill up E-85. 75e-85 25gas i guess its the new word on the streets. havnt tryed it yet tho
Old Aug 5, 2008 | 12:25 AM
BigDaddyBry's Avatar
If you use ethanol, remember not to buy pure ethanol. That **** is taxed. You buy the denatured kind. And don't drink it, you could go blind.
Old Aug 5, 2008 | 02:15 AM
bczee's Avatar
Try Seafoaming the car.. really help if you can get rid of some of that carbon build up. Make sure your cats are really hot !,.. go for a highway cruise or drive around 10-15 in a lower gear to get engine and cat hot.!!
Clean the Throttle Body and intake. Change the oil and plugs
and see about a tuner to check and adjust the A/F and idle. Make sure you don't have ay vacuum leaks.
Also try getting the test done 1st thing in the morning.
Old Aug 5, 2008 | 01:25 PM
Thanks, everyone. I've got some Seafoam laying around, so maybe I'll try that and hedge my bet with some alky.
