Western Members CA, AZ, NV, UT, CO, NM, HI
Same problems after new plugs and wires. Help!!
Old Aug 12, 2008 | 11:25 PM
camarossls12001's Avatar
Default Same problems after new plugs and wires. Help!!
Just installed the new MSD 8.5 wires and TR55 plugs and I still have a bad misfire problem. I took it out and drove it around watching the misfire data and found that 1 had 20, 2 had 17, 3 had 92, 4 had 4, 5 had 177, 6 had 344, 7 had 3, and 8 had 4 misfires. The two codes that are still coming up are P0300 engine misfire detected and P0353 #3 coil circuit control. O2's are reading good. Anyone have any idea what this might be tied together by?
Old Aug 12, 2008 | 11:29 PM
jsteele90's Avatar
bad coils?
hlaalu's Avatar
bad coil packs?
Old Aug 12, 2008 | 11:43 PM
warp_6's Avatar
Did this start after the flywheel was installed?
Old Aug 12, 2008 | 11:53 PM
7camaro7's Avatar
thinking coils, but find out hwat may have made them go bad. I had that po300 code before. I had an exhaust leak on my passenger side header where the AIR connections are. I swapped plugs wires and coils and fixed the leak and everything was fine
Old Aug 12, 2008 | 11:57 PM
hlaalu's Avatar
could an exhaust leak cause a misfire as well?
Old Aug 12, 2008 | 11:59 PM
00SSLS1's Avatar
did you make sure you heard the clicks when you installed the new wires?
Old Aug 13, 2008 | 12:04 AM
98BlkFormula's Avatar
no it cant, it could be the coils and im not 100% sure about this but if its not your coils it could also be a fuel problem (injectors) or the ECU
Old Aug 13, 2008 | 12:06 AM
01SOMSS!'s Avatar
swap the coils from your other car.
Old Aug 13, 2008 | 12:12 AM
00SSLS1's Avatar
nevermind just saw that this was already and existing problem
Old Aug 13, 2008 | 12:23 AM
I am pretty sure it was happening before the flywheel but this has been off and on since I bought the car in 03 with 43K it now has 83K. I changed plugs first time around 60k and found one NGK plug possibly in #5 but not sure the rest had AC Delco's. I think it was the #3 coil that I also replaced because of the same code before first plugs change. I did the wires about 65K. I don't want to steal good parts from one car if this one is just going to screw them up too or I would swap coils.
Old Aug 13, 2008 | 12:37 AM
00SSLS1's Avatar
it shouldnt screw them up, swap over the coils if the problem goes away you know your answer
Old Aug 13, 2008 | 01:14 AM
7camaro7's Avatar
then why did I just say it can?!
it can and it did, on my car last summer and this year too. If the leak is in front of the o2 sensors, they will pick up the added oxygen entering the exhaust and try to compensate (the correct air/fuel mixture) by adding more fuel to the cylinders, which in turn fouls the plugs out. FOULED OUT PLUGS = MISFIRE!
PROVE ME WRONG!
If he has the po300 code which means, "multiple and random misfire," then swapping coils won't do jack.
If he swaps all the coils to another ls1 and vice versa that may tell something.
Old Aug 13, 2008 | 02:06 AM
BigDaddyBry's Avatar
Seriously dude, what did you think he was gonna do, swap them left to right? Random misfires, every cylinder, think about it.
Check his sig too.
Old Aug 13, 2008 | 10:50 AM
PROVE ME WRONG!
well im no mechanic but maybe your right. But topic says he just changed his plugs and wires so im guessing its not his plugs...and if its not his plugs then its not an leak right?
Old Aug 13, 2008 | 01:02 PM
7camaro7's Avatar
^ is the name of the thread. That makes me think he had problems before the plug swap. Which means it still could be coils. When I had his problem i went about it the same exact way he did to fix it. I did plugs first, then wires, and finally bought coils which fixed the problem. The ultimate cause of my problem was one of the A.I.R. tubes which was on the passenger side had lost a bolt and nut. So I had a pretty bad leak right at the very beginning of my exhaust. That fouled my plugs(turned them black, I still may have them lying around somewhere, I may take pics later). LONG STORY SHORT... All of his stuff MAY need changing which includes plugs(definitely), wires(possibly), and in this case coils(definitely).
Check his sig too.
Read below slowly.
The guy who I was talking to, did not specifically say buy and install new coils, nor swap coils from one vehicle to the next. Swapping coils usually means place the same ones in different areas on the same car. That's what I thought he meant.
you should tell your friend to be more specific
seriously dude.
Old Aug 13, 2008 | 05:43 PM
Old plugs were fine the gap was .045 on them (AC Delco Iridiums) I broke one of them taking them out and checking gap so got new ones. Old wires were fine with the exception of the #7 which was rusted at the spark plug connection and broke off when I took the wire off to check it. So thats why I was suspecting bad plugs and wires. Today I checked for loose connectors by wiggeling all wiring harnesses(car running and no change in misfires), checked for bad connection of fuses and blown fuses. Had someone suggest checking for broken valve spring but I think I would have worse problems... Like I said this problem comes and goes and is more noticable when the car is hot and grater than 50% throttle. But than again sometimes no problems at all and it runs great.
Old Aug 13, 2008 | 07:11 PM
hlaalu's Avatar
yea i would just put on your coils from your good car ( i know its a pain in the ***) on your bad car, fire it up and check for misfires. process of elimination. like others said you won't damage them, so dont worry.
Old Aug 13, 2008 | 08:16 PM
7camaro7's Avatar
make it easy for yourself and just swap the complete brackets and coils between vehicles.
Old Aug 13, 2008 | 08:23 PM
hlaalu's Avatar
^yup just a few screws to take off
